alperry6 Posted January 21, 2015 Share Posted January 21, 2015 I opened an AutoCAD drawing of a building (not done in AutoCAD Architecture) and the entire layout was blocked. I attempted the explode command and it didn't change anything. I was able to go into the block editor, copy all contents, and paste it into a new blank drawing. Once pasted, it was no longer a block. Anyone experience that before, where you're not able to explode a block? Is there a way to lock/unlock blocks? Quote Link to comment Share on other sites More sharing options...
CheSyn Posted January 21, 2015 Share Posted January 21, 2015 In the Block Definition window, you can toggle "Allow exploding" in the Behavior section. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted January 21, 2015 Share Posted January 21, 2015 If the block is set up so that you cannot explode it, run the BEDIT command to open the block in the block editor. Once in the editor, open your Properties palette and scroll down to the "Block" section at the bottom of the palette. There you can set "Allow Exploding" to Yes. Save and Close the block editor and you should be able to explode the block. Quote Link to comment Share on other sites More sharing options...
