I've tried macros, have done FLATTEN, and tried to set Z coordinates to zero multiple times, but still have a corrupt file that does not have all line art on Z=0.
I need help flattening two plan files so that line art will show all coordinates at Z=). I will consider sharing via Dropbox if someone with a good showing & history on this site will help. Can also look into compensation via PayPal if desired.
This is an ongoing problem for me and has been exacerbated by going between Revit, AutoCAD, and Sketchup, which sometimes exports 3D data. Email feature from cadtutor has been enabled, please contact via email. Sincerely,
If you can provide one of your drawing files, I'm sure someone here will take a look. No need for compensation, we're here to help.
try this.. in PLAN view
Move
All
0,0,0
0,0,0e99
Move
Previous
0,0,0
,0,0,-0e99
Thank you, Happy. I think this worked.
You probably don't even need to supply the whole drawing, if you have reason not to want to do that, just pick out a few of the items that are causing problems and put them into a separate drawing, someone should be able to see where the problem is occuring.
Don't forget the old CHANGE command and ELEVATION option.
