Guest Posted January 24, 2015 Posted January 24, 2015 Hi Hippe013 is any way this lisp to support lines and polylines? In this code we selecti a line and convert it to 3d polyline, I it posible to select a 2d polylione and convert it to 3d polyline ;Drapes a 3dpolyline over polylines along a selected line. (vl-load-com) (defun c:sample-pl ( / li *ModSpc *ActDoc *Acad lobj p1 p2 ss sslen i plobj pnts n li pntli finli var) (setq li nil) (setq *ModSpc (vlax-get-property (setq *ActDoc (vlax-get-property (setq *acad (vlax-get-acad-object)) 'ActiveDocument)) 'ModelSpace)) (setq lobj (vlax-ename->vla-object (car (entsel "\nSelect Line Object: ")))) (setq p1 (vlax-safearray->list (vlax-variant-value (vlax-get-property lobj 'StartPoint)))) (setq p2 (vlax-safearray->list (vlax-variant-value (vlax-get-property lobj 'EndPoint)))) (setq ss (ssget "f" (list p1 p2) '(( 0 . "LWPOLYLINE")))) (setq sslen (sslength ss)) (setq i 0) (repeat sslen (setq plobj (vlax-ename->vla-object (ssname ss i))) (setq el (vlax-get-property plobj 'Elevation)) (vlax-put-property plobj 'Elevation 0) (setq pnts (vlax-invoke lobj 'IntersectWith plobj acExtendNone)) (vlax-put-property plobj 'Elevation el) (vlax-release-object plobj) (setq n 0) (repeat (/ (length pnts) 3) (setq li (append li (list (nth (+ n 0) pnts)))) (setq li (append li (list (nth (+ n 1) pnts)))) (setq li (append li (list el))) (drxc (list (nth (+ n 0) pnts) (nth (+ n 1) pnts) el) 2) (setq n (+ n 3)) ) (setq i (1+ i)) ) (setq n 0) (setq pntli nil) (repeat (/ (length li) 3) (setq pntli (append pntli (list (cons (distance (list (nth (+ n 0) li) (nth (+ n 1) li)) (list (nth 0 p1) (nth 1 p1))) (list (list (nth (+ n 0) li) (nth (+ n 1) li)(nth (+ n 2) li))))))) (setq n (+ n 3)) ) (setq pntli (vl-sort pntli (function (lambda (d1 d2) (< (car d1) (car d2)))))) (setq n 0) (setq finli nil) (repeat (length pntli) (setq finli (append finli (cadr (nth n pntli)))) (setq n (1+ n)) ) (setq var (pl->var finli)) (setq 3dobj2 (vlax-invoke-method *ModSpc 'Add3DPoly var)) (vlax-put-property 3dobj2 'Color 1) (vlax-release-object 3dobj2) ) ;Given Pointlist returns pointlist in variant form (defun PL->VAR ( pl / pl ub sa var) (setq ub (- (length pl) 1)) (setq sa (vlax-make-safearray vlax-vbdouble (cons 0 ub))) (setq var (vlax-make-variant (setq sa (vlax-safearray-fill sa pl)))) ) ;Graphically at given point and color Example (drxc '( 1 2 3) 1) draws x at x=1 y=2 z=3 in the color red (defun drxc (ctr color / vs xs xs2 cor1 cor2 cor3 cor4 ctr color) (setq vs (getvar "viewsize")) (setq xs (/ vs 20)) (setq xs2 (/ xs 2)) (setq cor1 (polar ctr (* pi 0.25) xs2)) (setq cor2 (polar ctr (* pi 0.75) xs2)) (setq cor3 (polar ctr (* pi 1.25) xs2)) (setq cor4 (polar ctr (* pi 1.75) xs2)) (grdraw ctr cor1 color 0) (grdraw ctr cor2 color 0) (grdraw ctr cor3 color 0) (grdraw ctr cor4 color 0) ) ;The following was written by LEE MAC ~ Cadtutor ;in response to my posting of the above code. (defun c:LWPolySample ( / _dxf doc spc lobj p1 ss ev tmp lst ) (vl-load-com) ;; © Lee Mac 2010 (defun _dxf ( code entity ) (cdr (assoc code (entget entity)))) (LM:ActiveSpace 'doc 'spc) (COMMAND "_layer" "_m" "3d polyline" "_c" "55" "" "" "") (if (and (setq lobj (car (entsel "\nSelect Line Object:"))) (eq "LINE" (_dxf 0 lobj)) (ssget "_F" (list (setq p1 (_dxf 10 lobj)) (_dxf 11 lobj)) '((0 . "LWPOLYLINE")) ) ) (progn (setq lobj (vlax-ename->vla-object lobj)) (vlax-for obj (setq ss (vla-get-ActiveSelectionSet doc)) (setq ev (vla-get-Elevation obj)) (vla-put-Elevation obj 0.0) (setq lst (cons (mapcar (function (lambda ( x ) (list (car x) (cadr x) ev)) ) (GroupByNum (vlax-invoke obj 'IntersectWith lobj acExtendNone) 3) ) lst ) ) (vla-put-Elevation obj ev) ) (vla-delete ss) (vla-put-Color (vlax-invoke spc 'Add3DPoly (apply 'append (vl-sort (apply 'append lst) '(lambda ( a b ) (< (distance p1 (list (car a) (cadr a))) (distance p1 (list (car b) (cadr b)))) ) ) ) ) ) ) ) (princ) ) (defun GroupByNum ( l n / r) ;; © Lee Mac 2010 (setq r (list (car l))) (if l (cons (reverse (repeat (1- n) (setq l (cdr l) r (cons (car l) r))) ) (GroupByNum (cdr l) n) ) ) ) ;;--------------------=={ ActiveSpace }==---------------------;; ;; ;; ;; Retrieves pointers to the Active Document and Space ;; ;;------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2010 - www.lee-mac.com ;; ;;------------------------------------------------------------;; ;; Arguments: ;; ;; *doc - quoted symbol (other than *doc) ;; ;; *spc - quoted symbol (other than *spc) ;; ;;------------------------------------------------------------;; (defun LM:ActiveSpace ( *doc *spc ) ;; © Lee Mac 2010 (set *spc (vlax-get-property (set *doc (vla-get-ActiveDocument (vlax-get-acad-object) ) ) (if (= 1 (getvar 'CVPORT)) 'PaperSpace 'ModelSpace) ) ) ) Thanks Quote
Hippe013 Posted January 29, 2015 Posted January 29, 2015 Have you tried Lee Macs version? I believe his code supports polylines. EDIT: I guess it doesn't. I suppose it is possible. I am wondering how and why you would use it along a polyline. Quote
Guest Posted January 29, 2015 Posted January 29, 2015 hi Hippe013 ,I try LWPolySample but working only for lines and i don't know why Quote
Hippe013 Posted January 29, 2015 Posted January 29, 2015 Lee is providing a filter (and with good reason) for accepting only a line. Find the code snippet: (eq "LINE" (_dxf 0 lobj)) Quote
Guest Posted January 30, 2015 Posted January 30, 2015 Hippe013 I delete this line (eq "LINE" (_dxf 0 lobj)) but nothing happend. When i select a LWPOLYLINE the only thing is to create a layer 3d polyline with nothing on it .... Quote
Hippe013 Posted January 30, 2015 Posted January 30, 2015 prodromosm, I didn't tell you to delete that line of code. I was pointing out which part of the code was the filter for a line. It has become clear that you are not understanding what the code is doing. In order to have it where you could select a polyline rather than a line the code would have to be rewritten. The original intent of the code was to drape a LINE onto various 2d polylines set at various elevations resulting in a 3dpolyline. regards, hippe013 Quote
Guest Posted January 30, 2015 Posted January 30, 2015 Yes Hippe013 but i ask if it posible to select a 2d polylione and convert it to 3d polyline ,and you tell me that Have you tried Lee Macs version? I believe his code supports polylines. How Lee Macs version supports polylines ? Quote
Hippe013 Posted January 30, 2015 Posted January 30, 2015 Neither one supports polylines as the draping object. Only lines. The code would have to be rewritten in order to support polylines as the drape object. Quote
Guest Posted January 30, 2015 Posted January 30, 2015 Can you do it if is not trouble for you. Thanks Quote
