Tharwat Posted January 20, 2015 Posted January 20, 2015 Use the same apply that I did for changing the linweight . eg. (if (and (eq (vla-get-objectname (car x)) "AcDbCircle") (eq (vla-get-linetype (car x)) "Continuous") ) (vla-put-lineweight [color="red"](car x)[/color] acLnWt035) ) One more thing , as I have reminded you earlier that there was a simple typo in my last reply and anyway I corrected here in this post as highlighted in RED above Quote
cadfan Posted January 20, 2015 Author Posted January 20, 2015 Use the same apply that I did for changing the linweight . eg. (if (and (eq (vla-get-objectname (car x)) "AcDbCircle") (eq (vla-get-linetype (car x)) "Continuous") ) (vla-put-lineweight [color="red"](car x)[/color] acLnWt035) ) One more thing , as I have reminded you earlier that there was a simple typo in my last reply and anyway I corrected here in this post as highlighted in RED above Thank you .Mr.Tharwat Ability is limited, can't understand . can you help me this time ? Quote
Tharwat Posted January 20, 2015 Posted January 20, 2015 The following codes to create objects as implemented into your codes . (setq cir (vlax-invoke space 'addcircle pcen r) arc (vlax-invoke space 'addarc pcen mr 4.71239 3.14159) ln1 (vlax-invoke space 'addline p1 p3) ln2 (vlax-invoke space 'addline p2 p4) ) Where variables : cir = circle arc = arc ln1 = first line ln2 = second line Then use the following method to move circle to a specific layer that should be existed in your drawing ; (vla-put-layer cir "screw") And the same should be used to any other objects . Quote
cadfan Posted January 20, 2015 Author Posted January 20, 2015 (edited) The following codes to create objects as implemented into your codes . (setq cir (vlax-invoke space 'addcircle pcen r) arc (vlax-invoke space 'addarc pcen mr 4.71239 3.14159) ln1 (vlax-invoke space 'addline p1 p3) ln2 (vlax-invoke space 'addline p2 p4) ) Where variables : cir = circle arc = arc ln1 = first line ln2 = second line Then use the following method to move circle to a specific layer that should be existed in your drawing ; (vla-put-layer cir "screw") And the same should be used to any other objects . Thank , Mr.Tharwat. (setq cir (vlax-invoke space 'addcircle pcen r) arc (vlax-invoke space 'addarc pcen mr 4.71239 3.14159) ln1 (vlax-invoke space 'addline p1 p3) ln2 (vlax-invoke space 'addline p2 p4) ) [color="red"] (vla-put-layer ln1 "centreline") (vla-put-layer ln2 "centreline")[/color] (mapcar '(lambda (x) (vlax-put (car x) 'layer "screw") (vlax-put (car x) 'color (cadr x)) (vlax-put (car x) "linetype" (caddr x)) (vlax-put (car x) "linetypescale" xk) ) (list (list cir 33 cel) (list arc 3 cel) (list ln1 1 "center") (list ln2 1 "center") ) ) Edited January 20, 2015 by cadfan Quote
marko_ribar Posted January 20, 2015 Posted January 20, 2015 Another... (defun c:tt (...) (defun _make (...) ... (setq cir (vlax-invoke space 'addcircle pcen r) arc (vlax-invoke space 'addarc pcen mr 4.71239 3.14159) ln1 (vlax-invoke space 'addline p1 p3) ln2 (vlax-invoke space 'addline p2 p4) ) (mapcar '(lambda (x) (vlax-put (car x) 'layer [color=red](cadr x)[/color]) (vlax-put (car x) 'color [color=red](caddr x)[/color]) (vlax-put (car x) "linetype" [color=red](cadddr x)[/color]) (vlax-put (car x) "linetypescale" xk) (if (and (eq (vla-get-objectname (car x)) "AcDbCircle") (eq (vla-get-linetype (car x)) "Continuous") ) (vla-put-lineweight (car x) acLnWt035) ) ) (list [color=red](list cir "screw" 33 cel) (list arc "screw" 3 cel) (list ln1 "centreline" 1 "center") (list ln2 "centreline" 1 "center")[/color] ) ) (if (member "isText" slst) (progn (setq txt (vlax-invoke space 'AddText str pcen (* mr 0.4))) (vla-put-alignment txt acAlignmentTopCenter) (vla-put-textalignmentpoint txt (vlax-3d-point (polar pcen (- _pi2) (* mr 0.17))) ) [color=red](vla-put-layer txt "text") [/color] ) ) (if (member "isBlock" slst) (vlax-invoke (fy:acspace) 'insertblock pcen (vla-get-name space) 1. 1. 1. 0. ) ) ) ... (if (and (= (xd::dcl:start id fn) 1 ) (setq ss (ssget '((0 . "circle") (-4 . "<or") (40 . 2.5) (40 . 3.3) (40 . 4.2) (40 . 5.0) (40 . 6. (40 . 8.5) (40 . 10.5) (40 . 12.0) (40 . 14.0) (40 . 15.5) (40 . 17.5) (-4 . "or>") ) ) ) ) (progn (if (not (tblsearch "style" "txt")) (command ".style" "txt" "txt.shx,gbcbig.shx" 0.0 1.0 0.0 "n" "n" "n" ) ) (if (not (tblsearch "ltype" "hidden")) (vla-load (fy:acltypes) "hidden" "acadiso.lin") ) (if (not (tblsearch "ltype" "center")) (vla-load (fy:acltypes) "center" "acadiso.lin") ) (if (not (tblsearch "layer" "screw")) (vla-add (fy:aclayers) "screw") ) [color=red](if (not (tblsearch "layer" "centreline")) (vla-add (fy:aclayers) "centreline") ) (if (not (tblsearch "layer" "text")) (vla-add (fy:aclayers) "text") )[/color] (mapcar '(lambda (x) (_make x)) (fy:cset->objs)) (if (member "isErased" slst) (command ".erase" ss "") ) ) ) (princ) ) Quote
cadfan Posted January 20, 2015 Author Posted January 20, 2015 (edited) Another... , Thank you ,marko. I will read carefully . TKS. Edited January 20, 2015 by cadfan Quote
cadfan Posted January 20, 2015 Author Posted January 20, 2015 Another... Hi marko . This modify is most beautiful . (mapcar '(lambda (x) (vlax-put (car x) 'layer [color="red"](cadr x)[/color]) (vlax-put (car x) 'color [color="red"](caddr x)[/color]) (vlax-put (car x) "linetype" [color="red"](cadddr x)[/color]) (vlax-put (car x) "linetypescale" xk) (if (and (eq (vla-get-objectname (car x)) "AcDbCircle") (eq (vla-get-linetype (car x)) "Continuous") ) (vla-put-lineweight (car x) acLnWt035) ) ) (list [color="red"](list cir "screw" 33 cel)[/color] [color="red"] (list arc "screw" 3 cel)[/color] [color="red"] (list ln1 "centreline" 1 "center")[/color] [color="red"] (list ln2 "centreline" 1 "center")[/color] ) ) Now , All problems have been solved ! Many thanks! Tharwat, Marko. Quote
