samifox Posted January 13, 2015 Share Posted January 13, 2015 hi, i've written some input validation code, and i wonder what is really required to code and what can be handled by the autolisp *error* function. secondly, for readability sake, since the validation code is long i were thinking to link it from a different sub-function . is this a good idea? (this function is not going to interact with the user so i didnt use the getinit codes) Thanks Shay ;;;--------------------------------------------------------------------; ;;; Function: setEntSeg(ent typ max min) ; ;;; Vesion: 0.0 ;;; Creation: ;;; Update: ;;; Sub-function : 3DTO2DpONIT() ;;; ; ;;; Description: divids entity into segments while maintaining ;;; typ segment length. when total length cannot be ;;; divided without a reminder. last segments being handled ;;; according to min max parameters. ;;; ;;; ; ;;; Arguments: ; ;;; typ = typical segment length. ; ;;; mn = integer. minimum length allowed. ; ;;; mx = integer. maximum length allowed. ; ;;; ; ;;; Returned Value: A list of 2d coordinates represanting the ;;; new segments. ;;; ; ;;; Usage: ; ;;; ; ;;;--------------------------------------------------------------------; (defun setEntSeg (ent mn typ mx / plst y x cnt ang) (if (= (cdr (assoc 0 ent)) "LWPOLYLINE") (if (not (and (zerop mn) (zerop typ) (zerop mx))) (if (and (or (= (type typ) 'INT)) (or (= (type mn) 'INT)) (or (= (type mx) 'INT)) ) (if (not (and (minusp mn) (minusp mx))) (if (and (> mx typ) (< mn typ)) (princ "input is valid\n") (princ "iilegeal values, make sure mx is greater than typ and mn is smaller than typ\n" ) ) (princ "negative values are not allowed\n") ) (princ "mn and/or mx must be integer\n") ) (princ "zero is not allowed/n") ) (princ "function works only with lwpolyline\n") ) (princ) ) (defun test () (setq ent (entmake (list (cons 0 "LWPOLYLINE") (cons 100 "AcDbEntity") (cons 100 "AcDbPolyline") (cons 90 2) (cons 10 (list 0 0)) (cons 10 (list 100 100)) (cons 210 (list 0 0 1)) ) ) ) (setEntSeg ent 6 6 6) ) Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 13, 2015 Share Posted January 13, 2015 (edited) eror checking If Not polyline do in loop with a exit option "you have not picked a pline please try again or pick nothing to exit" de. Its a bit late if they have picked an object then they have no 2nd go. now where is my code example trying to find uses a while to check if NIL no object picked then (exit). (while (setq obj (entget (car (entsel "\nPick Pline")))) (if (= (cdr (assoc 0 obj)) "LWPOLYLINE") (progn ; your code ; your code (princ "wow") ; your code ; your code (exit) ; to get out of while ) ; end progn (alert (strcat "You picked a " (cdr (assoc 0 obj)) " try again nothing to exit")) ) ; end if ) ; end while Edited January 13, 2015 by BIGAL Quote Link to comment Share on other sites More sharing options...
samifox Posted January 13, 2015 Author Share Posted January 13, 2015 (edited) thanks Bigal. as i said, input verification will take place in the getInput() function. still have the same wonders thu... Edited January 13, 2015 by samifox Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted January 14, 2015 Share Posted January 14, 2015 Does [url="http://help.autodesk.com/view/ACD/2015/ENU/?guid=GUID-7BA45202-D95F-4F2D-8D83-965024826074"]cond[/url] helps? Quote Link to comment Share on other sites More sharing options...
samifox Posted January 20, 2015 Author Share Posted January 20, 2015 What *error* can handle and what i can handle? Quote Link to comment Share on other sites More sharing options...
