Joshbmc Posted January 12, 2015 Share Posted January 12, 2015 Hi, Recently downloaded autocad 2015... I try drawing a rectangle using rectang command, but it comes out super thick (the thickness command in rectang was 0.000). I havn't had this problem in 2014 autocad. Anyone know anything about this? Thanks Josh Quote Link to comment Share on other sites More sharing options...
nestly Posted January 12, 2015 Share Posted January 12, 2015 "Thickness" is in the Z direction... that appears to be a "width" issue. It looks to me like the "width" of the PLINE is nearly the same value as the Y dimension for the Rectangle. Did you manually assign the width of the PLINE and/or change PLINEWID sysvar from the default value of 0 Quote Link to comment Share on other sites More sharing options...
Joshbmc Posted January 12, 2015 Author Share Posted January 12, 2015 All sorted now, I must have changed the rectangle line width by mistake instead of dimensions of rectangle Quote Link to comment Share on other sites More sharing options...
