well im a relative novice when it comes to rendering. i just clicked a bunch of buttons until this looked right:)
  • Replies 26
  • rustysilo
    14
  • shift1313
    10
  • Cad64
    2
  • spursnutter
    1
Posted Images
Why does the lighting intensity seem to change when you render from different perspectives and/or positions?
maybe your seeing the reflection in a certain viewing angle?
I guess so. It renders brighter in some places. If I'm zoomed in looking straight at the object(s) it is a little dim, then after zooming out some it gets brighter. If I change to another perspective it appears more dim too. I guess the reflection of the light is stronger or weaker depending on where you're looking at it from. That makes sense, but then if you actually want a render from another perspective you have to change the lighting.:unsure:
you can try creating a room around the logo and playing with the material on the walls to reflect or absorb light.
  shift1313 said:
brass in solidworks
gold in solidworks
What did you use for the material of the table here shift?
its a standard scene in photoworks 360. not sure, just a studio environment.
