pBe Posted January 12, 2015 Share Posted January 12, 2015 It works, Thank You Good for you and you are welcome Quote Link to comment Share on other sites More sharing options...
dina lopez Posted June 28, 2015 Share Posted June 28, 2015 WOULD YOU explain how to convert it into a lisp routine file and what to type at the command line and how to transfer the csv excel file into auto cad to create the polyline with the elevations. thanks. dina Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 29, 2015 Share Posted June 29, 2015 You want to do the reverse of the Post theme its so simple to do in excel just create a new column the very first row is 3dpoly the next row you use the concatenate command to make a X,Y,Z then just simply copy the column to the autocad command line. Quote Link to comment Share on other sites More sharing options...
aldea Posted June 29, 2015 Share Posted June 29, 2015 WOULD YOU explain step by step how to use this lisp routine. thanks. d Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 30, 2015 Share Posted June 30, 2015 I thought my image was very clear, copy the formula down for the number of x,y,z lines you have, then copy column "E" to the Autocad command line. Quote Link to comment Share on other sites More sharing options...
