I have several A4 pages in pdf format printed from autocad. Since these pages are printed via lisp I have their local addresses in lisp variables.
(setq page1 "\\pdf\page1.pdf" etc.)
I then use "PDF Merge Tool" to combine these pages manually to create a single pdf file - instruction manual.
Is it possible to combine pdf file via Lisp ?
All help is appreciated.
I assume you have the AutoCAD source .DWG. Why not publish to a single multipage .PDF file directly from AutoCAD?
Spaj : These pdf files are printed within a lisp routine that changes certain values, freezes /unfreezes layers, adds lines etc according to user input. The dwg is only in model space. So I don't think I can use publish.
I take it your Pdf merge tool is a external program if so you can use "Shell" which opens a operating system window that you can send commands to.
Something like ("shell" "notepad")
  • 1 year later...
Hi,
This might be of help to someone.
Mearging pdf files can done quite easily with Ghostscript.
read here
Roy_043 posted this :
(defun KGA_String_Join (strLst delim)
(if strLst (apply  'strcat (cons (car strLst)
(mapcar '(lambda (a) (strcat delim a)) (cdr strLst)))) ""   ) )
; (CombinePdf
;   "C:\\Program Files\\gs\\gs8.61\\bin\\gswin32c.exe"
;   '("D:\\Tmp\\A.pdf" "D:\\Tmp\\B.pdf") ;   "D:\\Tmp\\Total.pdf" ; )
; Note: Existing trgFile will be overwritten.
(defun CombinePdf (gsExe srcFileLst trgFile)
(startapp     (strcat       gsExe " "       "-dBATCH -dNOPAUSE -dQUIET -sDEVICE=pdfwrite "
                                         "-sOutputFile=\"" trgFile "\" "
                                        "\"" (KGA_String_Join srcFileLst "\" \"") "\""     )   ) )
You need to install Ghostcript - it's a freeware.
Edited by sadhu
A further version thanks to roy_043
;Plots layouts by range
; By Alan H Feb 2014
(defun AH:pltlays ( / pdfname lay numlay numend)
(SETVAR "PDMODE" 0)
(setvar "fillmode" 1)
(setvar "textfill" 1)
(setq plotnames '())
(if (not AH:getval2) (load "getvals"))
(ah:getval2 "Enter start tab number" 6 4 "Enter end tab number" 6 4)
(setq numlay (ATOI val1))
(setq numend (ATOI val2))
(setq len (+ (- numend numlay) 1))
(setq dwgname (GETVAR "dwgname"))
(setq lendwg (strlen dwgname))
(setq dwgname (substr dwgname 1 (- lendwg 4)))
(repeat len
(vlax-for lay (vla-get-Layouts (vla-get-activedocument (vlax-get-acad-object)))
(if (= numlay (vla-get-taborder lay))
 (setvar "ctab" (vla-get-name lay))
) ; if
(setq pdfname (strcat (getvar "dwgprefix") "pdf\\" dwgname "-" (getvar "ctab") ".pdf" ))
) ; for
(setq lay nil)
   (COMMAND "-PLOT"  "Y"  "" "dwg to Pdf"
       "Iso full bleed A3 (420.00 x 297.00 MM)" "m" "LANDSCAPE"  "N"   "W"  "-6,-6" "807,560" "1=2"  "C"
       "y" "Designlasercolour.ctb" "Y" "n" "n" "n" pdfName "N" "y"
(setq numlay (+ numlay 1))
(setq plotnames (cons pdfname plotnames))
) ; end repeat
(setq trgfile (strcat (getvar "dwgprefix") "pdf\\" dwgname "-D" val1 "-D" val2 ".pdf"))
) ; defun
(AH:pltlays)
(if (not combinepdf)(load "mergepdfs"))
(combinepdf gsExe plotnames trgFile )
(setq plotnames nil
          val1 nil
          val2 nil)
;MergePdfs
;Merges multiple pdf (or eps) files into one
; make a batch file ?
;gs -sDEVICE=pdfwrite \
;    -dNOPAUSE -dBATCH -dSAFER \
;    -sOutputFile=combined.pdf \
;    first.pdf \
;    second.pdf \
;    third.pdf [...]
;Ghostscript ([url]http://www.ghostscript.com/[/url]) can be used to combine PDFs.
; Something like this should work: by Roy_043
(if strLst
(apply
'strcat
(cons
(car strLst)
(setq gsexe "C:\\Program Files\\gs\\gs9.19\\bin\\gswin64c.exe")
(startapp
(strcat
gsExe " "
"-sDEVICE=pdfwrite -dBATCH -dNOPAUSE -dQUIET  "
GETVALS.lsp
  • 5 years later...
Hello sir
i have merged the code of plot (ah:pltlays)  with the lisp of merge pdf
but it don't merge the pdfs
can you help me about that ??
i have uploaded the lisp that i have made and i which you help me about that
thanks in advance
plot lisp & GETVALS lisp inside it .lsp
Its a 5 year old post, you need to mention that you need to download Ghostscript and check where you save it to
eg (setq gsexe "D:\\gs\\gs9.55.0\\bin\\gswin64c.exe")
thanks about that
I need to delete the other separate pdfs
can I make that ??
  • 6 months later...
Did you get anywhere on the deleting of the single separate pdfs?  I also need this.  My only thought is to have it dump the single pages in a tmp folder.
just a thought (in case you don't have ghostscript or unable to install it) first attach each separate pdf to a dwg (script / lisp) and then publish all dwgs to a single pdf.
If you look at my code the list of file names is made here (setq plotnames (cons pdfname plotnames)) and the files are in a directory \PDF under the current dwg location, there is VL-delete-file . So could do a Foreach loop and delete files.
