The lisp is finally updated and tested and ready for using in all situations where current UCS is parallel to WCS...
[b][color=#FF0000]([/color][/b][color=BLUE]defun[/color] c:aplin [b][color=#80FF00]([/color][/b] [color=BLUE]/[/color] *error* *adoc* pt opt ptt el esel ent pent ang real difang nang ptw [b][color=#80FF00])[/color][/b]
 [b][color=#80FF00]([/color][/b][color=BLUE]defun[/color] *error* [b][color=#00FFFF]([/color][/b] msg [color=BLUE]/[/color] pea ss [b][color=#00FFFF])[/color][/b]
   [b][color=#00FFFF]([/color][/b][color=BLUE]setq[/color] pea [b][color=#0080FF]([/color][/b][color=BLUE]getvar[/color] 'peditaccept[b][color=#0080FF])[/color][/b][b][color=#00FFFF])[/color][/b]
   [b][color=#00FFFF]([/color][/b][color=BLUE]setvar[/color] 'peditaccept 1[b][color=#00FFFF])[/color][/b]
   [b][color=#00FFFF]([/color][/b][color=BLUE]if[/color] el
     [b][color=#0080FF]([/color][/b][color=BLUE]progn[/color]
       [b][color=#FF00FF]([/color][/b][color=BLUE]setq[/color] ss [b][color=#FF0000]([/color][/b][color=BLUE]ssadd[/color][b][color=#FF0000])[/color][/b][b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]foreach[/color] l el
         [b][color=#FF0000]([/color][/b][color=BLUE]ssadd[/color] l ss[b][color=#FF0000])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]command[/color] [color=BROWN]"_.PEDIT"[/color] [color=BROWN]"_M"[/color] ss [color=BROWN]""[/color] [color=BROWN]"_J"[/color][b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]while[/color] [b][color=#FF0000]([/color][/b][color=BLUE]>[/color] [b][color=#80FF00]([/color][/b][color=BLUE]getvar[/color] 'cmdactive[b][color=#80FF00])[/color][/b] 0[b][color=#FF0000])[/color][/b] [b][color=#FF0000]([/color][/b][color=BLUE]command[/color] [color=BROWN]""[/color][b][color=#FF0000])[/color][/b][b][color=#FF00FF])[/color][/b]
   [b][color=#00FFFF]([/color][/b][color=BLUE]setvar[/color] 'peditaccept pea[b][color=#00FFFF])[/color][/b]
   [b][color=#00FFFF]([/color][/b][color=BLUE]if[/color] msg [b][color=#0080FF]([/color][/b][color=BLUE]prompt[/color] msg[b][color=#0080FF])[/color][/b][b][color=#00FFFF])[/color][/b]
   [b][color=#00FFFF]([/color][/b][color=BLUE]princ[/color][b][color=#00FFFF])[/color][/b]
 [b][color=#80FF00]([/color][/b][color=BLUE]vl-load-com[/color][b][color=#80FF00])[/color][/b]
 [b][color=#80FF00]([/color][/b][color=BLUE]setq[/color] *adoc* [b][color=#00FFFF]([/color][/b][color=BLUE]vla-get-activedocument[/color] [b][color=#0080FF]([/color][/b][color=BLUE]vlax-get-acad-object[/color][b][color=#0080FF])[/color][/b][b][color=#00FFFF])[/color][/b][b][color=#80FF00])[/color][/b]
 [b][color=#80FF00]([/color][/b][color=BLUE]setq[/color] pt [b][color=#00FFFF]([/color][/b][color=BLUE]getpoint[/color] [color=BROWN]"\nSpecify first point : "[/color][b][color=#00FFFF])[/color][/b][b][color=#80FF00])[/color][/b]
 [b][color=#80FF00]([/color][/b][color=BLUE]while[/color]
   [b][color=#00FFFF]([/color][/b][color=BLUE]and[/color]
     pt
     [b][color=#0080FF]([/color][/b][color=BLUE]setq[/color] opt [b][color=#FF00FF]([/color][/b][color=BLUE]cons[/color] pt opt[b][color=#FF00FF])[/color][/b][b][color=#0080FF])[/color][/b]
     [b][color=#0080FF]([/color][/b][color=BLUE]not[/color] [b][color=#FF00FF]([/color][/b][color=BLUE]initget[/color] 128[b][color=#FF00FF])[/color][/b][b][color=#0080FF])[/color][/b]
     [b][color=#0080FF]([/color][/b][color=BLUE]setq[/color] ptt [b][color=#FF00FF]([/color][/b][color=BLUE]getpoint[/color] pt [color=BROWN]"\nSpecify next point or - F8 for orthomode [Angle line/Undo] : "[/color][b][color=#FF00FF])[/color][/b][b][color=#0080FF])[/color][/b]
     [b][color=#0080FF]([/color][/b][color=BLUE]setq[/color] opt [b][color=#FF00FF]([/color][/b][color=BLUE]cons[/color] ptt opt[b][color=#FF00FF])[/color][/b][b][color=#0080FF])[/color][/b]
   [b][color=#00FFFF]([/color][/b][color=BLUE]cond[/color]
     [b][color=#0080FF]([/color][/b] [b][color=#FF00FF]([/color][/b][color=BLUE]eq[/color] [b][color=#FF0000]([/color][/b][color=BLUE]type[/color] ptt[b][color=#FF0000])[/color][/b] '[color=BLUE]list[/color][b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]vla-startundomark[/color] *adoc*[b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]command[/color] [color=BROWN]"_.LINE"[/color] [color=BROWN]"_non"[/color] pt [color=BROWN]"_non"[/color] ptt [color=BROWN]""[/color][b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]setq[/color] el [b][color=#FF0000]([/color][/b][color=BLUE]cons[/color] [b][color=#80FF00]([/color][/b][color=BLUE]entlast[/color][b][color=#80FF00])[/color][/b] el[b][color=#FF0000])[/color][/b][b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]setvar[/color] 'orthomode 0[b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]setq[/color] pt ptt[b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]vla-endundomark[/color] *adoc*[b][color=#FF00FF])[/color][/b]
     [b][color=#0080FF]([/color][/b] [b][color=#FF00FF]([/color][/b][color=BLUE]or[/color] [b][color=#FF0000]([/color][/b][color=BLUE]wcmatch[/color] ptt [color=BROWN]"a*"[/color][b][color=#FF0000])[/color][/b] [b][color=#FF0000]([/color][/b][color=BLUE]wcmatch[/color] ptt [color=BROWN]"A*"[/color][b][color=#FF0000])[/color][/b][b][color=#FF00FF])[/color][/b]
         [b][color=#FF0000]([/color][/b][color=BLUE]or[/color]
           [b][color=#80FF00]([/color][/b][color=BLUE]not[/color] [b][color=#00FFFF]([/color][/b][color=BLUE]setq[/color] esel [b][color=#0080FF]([/color][/b][color=BLUE]entsel[/color] [color=BROWN]"\nPick target curve to obtain its angle"[/color][b][color=#0080FF])[/color][/b][b][color=#00FFFF])[/color][/b][b][color=#80FF00])[/color][/b]
           [b][color=#80FF00]([/color][/b][color=BLUE]vl-catch-all-error-p[/color] [b][color=#00FFFF]([/color][/b][color=BLUE]vl-catch-all-apply[/color] '[color=BLUE]vlax-curve-getstartparam[/color] [b][color=#0080FF]([/color][/b][color=BLUE]list[/color] [b][color=#FF00FF]([/color][/b][color=BLUE]car[/color] esel[b][color=#FF00FF])[/color][/b][b][color=#0080FF])[/color][/b][b][color=#00FFFF])[/color][/b][b][color=#80FF00])[/color][/b]
         [b][color=#FF0000]([/color][/b][color=BLUE]prompt[/color] [color=BROWN]"\nMissed or picked enitiy doesn't belong to curves... Try picking target curve again..."[/color][b][color=#FF0000])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]setq[/color] ent [b][color=#FF0000]([/color][/b][color=BLUE]car[/color] esel[b][color=#FF0000])[/color][/b][b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]setq[/color] pent [b][color=#FF0000]([/color][/b][color=BLUE]vlax-curve-getclosestpointto[/color] ent [b][color=#80FF00]([/color][/b][color=BLUE]trans[/color] [b][color=#00FFFF]([/color][/b][color=BLUE]cadr[/color] esel[b][color=#00FFFF])[/color][/b] 1 0[b][color=#80FF00])[/color][/b][b][color=#FF0000])[/color][/b][b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]setq[/color] ang [b][color=#FF0000]([/color][/b][color=BLUE]angle[/color] '[b][color=#80FF00]([/color][/b]0.0 0.0[b][color=#80FF00])[/color][/b] [b][color=#80FF00]([/color][/b][color=BLUE]vlax-curve-getfirstderiv[/color] ent [b][color=#00FFFF]([/color][/b][color=BLUE]vlax-curve-getparamatpoint[/color] ent pent[b][color=#00FFFF])[/color][/b][b][color=#80FF00])[/color][/b][b][color=#FF0000])[/color][/b][b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]initget[/color] 1[b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]setq[/color] real [b][color=#FF0000]([/color][/b][color=BLUE]getreal[/color] [color=BROWN]"\nSpecify angle to picked curve in decimal degrees : "[/color][b][color=#FF0000])[/color][/b][b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]setq[/color] difang [b][color=#FF0000]([/color][/b][color=BLUE]cvunit[/color] real [color=BROWN]"degree"[/color] [color=BROWN]"radian"[/color][b][color=#FF0000])[/color][/b][b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]setq[/color] nang [b][color=#FF0000]([/color][/b][color=BLUE]cvunit[/color] [b][color=#80FF00]([/color][/b][color=BLUE]+[/color] ang difang[b][color=#80FF00])[/color][/b] [color=BROWN]"radian"[/color] [color=BROWN]"degree"[/color][b][color=#FF0000])[/color][/b][b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]setq[/color] ptw [b][color=#FF0000]([/color][/b][color=BLUE]trans[/color] pt 1 0[b][color=#FF0000])[/color][/b][b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]command[/color] [color=BROWN]"_.UCS"[/color] [color=BROWN]"_W"[/color][b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]command[/color] [color=BROWN]"_.UCS"[/color] [color=BROWN]"_Z"[/color] nang[b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]setvar[/color] 'orthomode 1[b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]command[/color] [color=BROWN]"_.LINE"[/color] [color=BROWN]"_non"[/color] [b][color=#FF0000]([/color][/b][color=BLUE]trans[/color] ptw 0 1[b][color=#FF0000])[/color][/b] [color=BROWN]"\\"[/color][b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]setq[/color] ptw [b][color=#FF0000]([/color][/b][color=BLUE]trans[/color] [b][color=#80FF00]([/color][/b][color=BLUE]getvar[/color] 'lastpoint[b][color=#80FF00])[/color][/b] 1 0[b][color=#FF0000])[/color][/b][b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]command[/color] [color=BROWN]"_.UCS"[/color] [color=BROWN]"_P"[/color][b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]setq[/color] pt [b][color=#FF0000]([/color][/b][color=BLUE]trans[/color] ptw 0 1[b][color=#FF0000])[/color][/b][b][color=#FF00FF])[/color][/b]
     [b][color=#0080FF]([/color][/b] [b][color=#FF00FF]([/color][/b][color=BLUE]or[/color] [b][color=#FF0000]([/color][/b][color=BLUE]wcmatch[/color] ptt [color=BROWN]"u*"[/color][b][color=#FF0000])[/color][/b] [b][color=#FF0000]([/color][/b][color=BLUE]wcmatch[/color] ptt [color=BROWN]"U*"[/color][b][color=#FF0000])[/color][/b][b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]if[/color] [b][color=#FF0000]([/color][/b][color=BLUE]eq[/color] [b][color=#80FF00]([/color][/b][color=BLUE]length[/color] opt[b][color=#80FF00])[/color][/b] 2[b][color=#FF0000])[/color][/b]
         [b][color=#FF0000]([/color][/b][color=BLUE]setq[/color] pt [color=BLUE]nil[/color][b][color=#FF0000])[/color][/b]
         [b][color=#FF0000]([/color][/b][color=BLUE]progn[/color]
           [b][color=#80FF00]([/color][/b][color=BLUE]if[/color] [b][color=#00FFFF]([/color][/b][color=BLUE]equal[/color] [b][color=#0080FF]([/color][/b][color=BLUE]cadr[/color] opt[b][color=#0080FF])[/color][/b] [b][color=#0080FF]([/color][/b][color=BLUE]cadddr[/color] opt[b][color=#0080FF])[/color][/b] 1e-8[b][color=#00FFFF])[/color][/b]
             [b][color=#00FFFF]([/color][/b][color=BLUE]setq[/color] opt [b][color=#0080FF]([/color][/b][color=BLUE]cddddr[/color] opt[b][color=#0080FF])[/color][/b][b][color=#00FFFF])[/color][/b]
             [b][color=#00FFFF]([/color][/b][color=BLUE]setq[/color] opt [b][color=#0080FF]([/color][/b][color=BLUE]cddr[/color] opt[b][color=#0080FF])[/color][/b][b][color=#00FFFF])[/color][/b]
           [b][color=#80FF00]([/color][/b][color=BLUE]if[/color] [b][color=#00FFFF]([/color][/b][color=BLUE]null[/color] opt[b][color=#00FFFF])[/color][/b]
             [b][color=#00FFFF]([/color][/b][color=BLUE]setq[/color] pt [color=BLUE]nil[/color][b][color=#00FFFF])[/color][/b]
             [b][color=#00FFFF]([/color][/b][color=BLUE]progn[/color]
               [b][color=#0080FF]([/color][/b][color=BLUE]command[/color] [color=BROWN]"_.UNDO"[/color] [color=BROWN]""[/color][b][color=#0080FF])[/color][/b]
               [b][color=#0080FF]([/color][/b][color=BLUE]setq[/color] el [b][color=#FF00FF]([/color][/b][color=BLUE]cdr[/color] el[b][color=#FF00FF])[/color][/b][b][color=#0080FF])[/color][/b]
               [b][color=#0080FF]([/color][/b][color=BLUE]setq[/color] pt [b][color=#FF00FF]([/color][/b][color=BLUE]cadr[/color] opt[b][color=#FF00FF])[/color][/b][b][color=#0080FF])[/color][/b]
     [b][color=#0080FF]([/color][/b] [b][color=#FF00FF]([/color][/b][color=BLUE]eq[/color] [b][color=#FF0000]([/color][/b][color=BLUE]type[/color] ptt[b][color=#FF0000])[/color][/b] 'str[b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]prompt[/color] [color=BROWN]"\nInvalid option keyword..."[/color][b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]setq[/color] opt [b][color=#FF0000]([/color][/b][color=BLUE]cddr[/color] opt[b][color=#FF0000])[/color][/b][b][color=#FF00FF])[/color][/b]
 [b][color=#80FF00]([/color][/b]*error* [color=BLUE]nil[/color][b][color=#80FF00])[/color][/b]
Regards, and Happy New Year and to all, cadfan...
M.R.
Edited by marko_ribar
code revised and renamed to better suit to what routine do
  • Replies 48
  • cadfan
    15
  • ReMark
    7
  • marko_ribar
    6
  • nestly
    6
Posted Images
M.R.
Very nice ! marko. you are always ready to help others, :thumbsup:
[b][color=#FF0000]([/color][/b][color=BLUE]defun[/color] c:alin [b][color=#80FF00]([/color][/b] [color=BLUE]/[/color] *adoc* pea pt opt ptt el esel ent pent ang real difang nang ptw ss [b][color=#80FF00])[/color][/b]
     pt
           [b][color=#80FF00]([/color][/b][color=BLUE]vl-catch-all-error-p[/color] [b][color=#00FFFF]([/color][/b][color=BLUE]vl-catch-all-apply[/color] '[color=BLUE]vlax-curve-getstartparam[/color] [b][color=#0080FF]([/color][/b][color=BLUE]list[/color] [b][color=#FF00FF]([/color][/b][color=BLUE]car[/color] [color=BLUE]esel[/color][b][color=#FF00FF])[/color][/b][b][color=#0080FF])[/color][/b][b][color=#00FFFF])[/color][/b][b][color=#80FF00])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]setq[/color] ent [b][color=#FF0000]([/color][/b][color=BLUE]car[/color] [color=BLUE]esel[/color][b][color=#FF0000])[/color][/b][b][color=#FF00FF])[/color][/b]
 [b][color=#80FF00]([/color][/b][color=BLUE]if[/color] [b][color=#00FFFF]([/color][/b][color=BLUE]not[/color] [b][color=#0080FF]([/color][/b][color=BLUE]null[/color] el[b][color=#0080FF])[/color][/b][b][color=#00FFFF])[/color][/b]
     [b][color=#0080FF]([/color][/b][color=BLUE]setq[/color] ss [b][color=#FF00FF]([/color][/b][color=BLUE]ssadd[/color][b][color=#FF00FF])[/color][/b][b][color=#0080FF])[/color][/b]
     [b][color=#0080FF]([/color][/b][color=BLUE]foreach[/color] l el
       [b][color=#FF00FF]([/color][/b][color=BLUE]ssadd[/color] l ss[b][color=#FF00FF])[/color][/b]
     [b][color=#0080FF]([/color][/b][color=BLUE]setq[/color] pea [b][color=#FF00FF]([/color][/b][color=BLUE]getvar[/color] 'peditaccept[b][color=#FF00FF])[/color][/b][b][color=#0080FF])[/color][/b]
     [b][color=#0080FF]([/color][/b][color=BLUE]setvar[/color] 'peditaccept 1[b][color=#0080FF])[/color][/b]
     [b][color=#0080FF]([/color][/b][color=BLUE]command[/color] [color=BROWN]"_.PEDIT"[/color] [color=BROWN]"_M"[/color] ss [color=BROWN]""[/color] [color=BROWN]"_J"[/color][b][color=#0080FF])[/color][/b]
     [b][color=#0080FF]([/color][/b][color=BLUE]while[/color] [b][color=#FF00FF]([/color][/b][color=BLUE]>[/color] [b][color=#FF0000]([/color][/b][color=BLUE]getvar[/color] 'cmdactive[b][color=#FF0000])[/color][/b] 0[b][color=#FF00FF])[/color][/b] [b][color=#FF00FF]([/color][/b][color=BLUE]command[/color] [color=BROWN]""[/color][b][color=#FF00FF])[/color][/b][b][color=#0080FF])[/color][/b]
     [b][color=#0080FF]([/color][/b][color=BLUE]setvar[/color] 'peditaccept pea[b][color=#0080FF])[/color][/b]
 [b][color=#80FF00]([/color][/b][color=BLUE]princ[/color][b][color=#80FF00])[/color][/b]
M.R.
wow ... you are great ! marko. Thank you .
Hi again... I've renamed my previous routine to "APLIN.LSP" and I've created new "ALIN.LSP"... The names are better associated to what routines are doing... For new "ALIN.LSP" I leave to you to figure its usage... Me thinks that it's also very useful giving the fact that I passed school drawing lines with triangles and straight tracking ruler...
[b][color=#FF0000]([/color][/b][color=BLUE]defun[/color] c:alin [b][color=#80FF00]([/color][/b] [color=BLUE]/[/color] *error* *adoc* pt ptt esel ent pent ang real difang nang [b][color=#80FF00])[/color][/b]
 [b][color=#80FF00]([/color][/b][color=BLUE]defun[/color] *error* [b][color=#00FFFF]([/color][/b] msg [b][color=#00FFFF])[/color][/b]
   [b][color=#00FFFF]([/color][/b][color=BLUE]vla-endundomark[/color] *adoc*[b][color=#00FFFF])[/color][/b]
 [b][color=#80FF00]([/color][/b][color=BLUE]vla-startundomark[/color] *adoc*[b][color=#80FF00])[/color][/b]
     [b][color=#0080FF]([/color][/b][color=BLUE]if[/color] [b][color=#FF00FF]([/color][/b][color=BLUE]not[/color] [b][color=#FF0000]([/color][/b][color=BLUE]eq[/color] [b][color=#80FF00]([/color][/b][color=BLUE]type[/color] pt[b][color=#80FF00])[/color][/b] '[color=BLUE]list[/color][b][color=#FF0000])[/color][/b][b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]if[/color] [b][color=#FF0000]([/color][/b][color=BLUE]null[/color] pt[b][color=#FF0000])[/color][/b]
         [b][color=#FF0000]([/color][/b][color=BLUE]setq[/color] pt [b][color=#80FF00]([/color][/b][color=BLUE]getpoint[/color] [color=BROWN]"\nSpecify first point : "[/color][b][color=#80FF00])[/color][/b][b][color=#FF0000])[/color][/b]
           [b][color=#80FF00]([/color][/b][color=BLUE]initget[/color] 128[b][color=#80FF00])[/color][/b]
           [b][color=#80FF00]([/color][/b][color=BLUE]setq[/color] pt [b][color=#00FFFF]([/color][/b][color=BLUE]getpoint[/color] [color=BROWN]"\nSpecify first point or \"Undo\" : "[/color][b][color=#00FFFF])[/color][/b][b][color=#80FF00])[/color][/b]
       [color=BLUE]t[/color]
     [b][color=#0080FF]([/color][/b][color=BLUE]if[/color] [b][color=#FF00FF]([/color][/b][color=BLUE]eq[/color] [b][color=#FF0000]([/color][/b][color=BLUE]type[/color] pt[b][color=#FF0000])[/color][/b] '[color=BLUE]list[/color][b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]progn[/color]
         [b][color=#FF0000]([/color][/b][color=BLUE]initget[/color] 128[b][color=#FF0000])[/color][/b]
         [b][color=#FF0000]([/color][/b][color=BLUE]setq[/color] ptt [b][color=#80FF00]([/color][/b][color=BLUE]getpoint[/color] pt [color=BROWN]"\nSpecify next point or \"Angle line\" - F8 orthomode : "[/color][b][color=#80FF00])[/color][/b][b][color=#FF0000])[/color][/b]
     [b][color=#0080FF]([/color][/b] [b][color=#FF00FF]([/color][/b][color=BLUE]and[/color] [b][color=#FF0000]([/color][/b][color=BLUE]eq[/color] [b][color=#80FF00]([/color][/b][color=BLUE]type[/color] pt[b][color=#80FF00])[/color][/b] '[color=BLUE]list[/color][b][color=#FF0000])[/color][/b] [b][color=#FF0000]([/color][/b][color=BLUE]eq[/color] [b][color=#80FF00]([/color][/b][color=BLUE]type[/color] ptt[b][color=#80FF00])[/color][/b] '[color=BLUE]list[/color][b][color=#FF0000])[/color][/b][b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]setq[/color] pt [color=BROWN]""[/color][b][color=#FF00FF])[/color][/b]
     [b][color=#0080FF]([/color][/b] [b][color=#FF00FF]([/color][/b][color=BLUE]and[/color] [b][color=#FF0000]([/color][/b][color=BLUE]eq[/color] [b][color=#80FF00]([/color][/b][color=BLUE]type[/color] pt[b][color=#80FF00])[/color][/b] '[color=BLUE]list[/color][b][color=#FF0000])[/color][/b] [b][color=#FF0000]([/color][/b][color=BLUE]or[/color] [b][color=#80FF00]([/color][/b][color=BLUE]wcmatch[/color] ptt [color=BROWN]"a*"[/color][b][color=#80FF00])[/color][/b] [b][color=#80FF00]([/color][/b][color=BLUE]wcmatch[/color] ptt [color=BROWN]"A*"[/color][b][color=#80FF00])[/color][/b][b][color=#FF0000])[/color][/b][b][color=#FF00FF])[/color][/b]
     [b][color=#0080FF]([/color][/b] [b][color=#FF00FF]([/color][/b][color=BLUE]and[/color] [b][color=#FF0000]([/color][/b][color=BLUE]eq[/color] [b][color=#80FF00]([/color][/b][color=BLUE]type[/color] pt[b][color=#80FF00])[/color][/b] '[color=BLUE]list[/color][b][color=#FF0000])[/color][/b] [b][color=#FF0000]([/color][/b][color=BLUE]eq[/color] [b][color=#80FF00]([/color][/b][color=BLUE]type[/color] ptt[b][color=#80FF00])[/color][/b] 'str[b][color=#FF0000])[/color][/b][b][color=#FF00FF])[/color][/b]
     [b][color=#0080FF]([/color][/b] [b][color=#FF00FF]([/color][/b][color=BLUE]or[/color] [b][color=#FF0000]([/color][/b][color=BLUE]wcmatch[/color] pt [color=BROWN]"u*"[/color][b][color=#FF0000])[/color][/b] [b][color=#FF0000]([/color][/b][color=BLUE]wcmatch[/color] pt [color=BROWN]"U*"[/color][b][color=#FF0000])[/color][/b][b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]entdel[/color] [b][color=#FF0000]([/color][/b][color=BLUE]entlast[/color][b][color=#FF0000])[/color][/b][b][color=#FF00FF])[/color][/b]
       [b][color=#FF00FF]([/color][/b][color=BLUE]setq[/color] pt [color=BLUE]nil[/color][b][color=#FF00FF])[/color][/b]
     [b][color=#0080FF]([/color][/b] [b][color=#FF00FF]([/color][/b][color=BLUE]eq[/color] [b][color=#FF0000]([/color][/b][color=BLUE]type[/color] pt[b][color=#FF0000])[/color][/b] 'str[b][color=#FF00FF])[/color][/b]
Regards, M.R.
Regards, M.R.
Hi marko , why this version can't draw line continuous ?
That's the main difference... You don't want always to continue... When you draw lines manually with hand, do you make lines without breaks? I often draw something on one part of drawing, and then I see something missing on the other part... This is very similar to that procedure and it allows you to specify desired inclination angle of line in reference to picked target curve, which is why its called "alin.lsp"... In time you'll see its purpose better when you get used to new ways of doing things... You'll see, we all just need some practice...
yes! maybe need some practice... ,thanks marko!
Oh I forgot to add distance option... Note that when "Angle line" is specified "LINE" command is activated with "PAUSE" inputs, so after you pick target curve, angle in relation to curve, you can specify distance although not shown as text message...
(defun c:alin ( / *error* *adoc* pt ptt [color=red]d dn[/color] esel ent pent ang real difang nang )
 (defun *error* ( msg )
   (vla-endundomark *adoc*)
   (if msg (prompt msg))
 (vl-load-com)
 (setq *adoc* (vla-get-activedocument (vlax-get-acad-object)))
 (vla-startundomark *adoc*)
 (while
   (and
     (if (not (eq (type pt) 'list))
       (if (null pt)
         (setq pt (getpoint "\nSpecify first point : "))
           (initget 128)
           (setq pt (getpoint "\nSpecify first point or \"Undo\" : "))
       t
     (if (eq (type pt) 'list)
         (initget 128)
         (setq ptt (getpoint pt "\nSpecify next point or \"Angle line\" - F8 orthomode : "))
       t
   (cond
     ( (and (eq (type pt) 'list) (eq (type ptt) 'list))
       [color=red](setq d (distance pt ptt))
       (initget 2)
       (setq dn (getreal (strcat "\nSpecify distance <" (rtos d 2 50) "> : ")))
       (if (null dn) (setq dn d))
       (setq ptt (polar pt (angle pt ptt) dn))[/color]
       (command "_.LINE" "_non" pt "_non" ptt "")
       (setvar 'orthomode 0)
       (setq pt "")
     ( (and (eq (type pt) 'list) (or (wcmatch ptt "a*") (wcmatch ptt "A*")))
       (while
         (or
           (not (setq esel (entsel "\nPick target curve to obtain its angle")))
           (vl-catch-all-error-p (vl-catch-all-apply 'vlax-curve-getstartparam (list (car esel))))
         (prompt "\nMissed or picked enitiy doesn't belong to curves... Try picking target curve again...")
       (setq ent (car esel))
       (setq pent (vlax-curve-getclosestpointto ent (trans (cadr esel) 1 0)))
       (setq ang (angle '(0.0 0.0) (vlax-curve-getfirstderiv ent (vlax-curve-getparamatpoint ent pent))))
       (initget 1)
       (setq real (getreal "\nSpecify angle to picked curve in decimal degrees : "))
       (setq difang (cvunit real "degree" "radian"))
       (setq nang (cvunit (+ ang difang) "radian" "degree"))
       (setq ptw (trans pt 1 0))
       (command "_.UCS" "_W")
       (command "_.UCS" "_Z" nang)
       (setvar 'orthomode 1)
       (command "_.LINE" "_non" (trans ptw 0 1) "\\")
       (while (> (getvar 'cmdactive) 0) (command ""))
       (command "_.UCS" "_P")
       (setq pt "")
     ( (and (eq (type pt) 'list) (eq (type ptt) 'str))
       (prompt "\nInvalid option keyword...")
     ( (or (wcmatch pt "u*") (wcmatch pt "U*"))
       (entdel (entlast))
       (setq pt nil)
     ( (eq (type pt) 'str)
 (*error* nil)
(defun c:aplin ( / *error* *adoc* pt opt ptt el [color=red]d dn[/color] esel ent pent ang real difang nang ptw )
 (defun *error* ( msg / pea ss )
   (setq pea (getvar 'peditaccept))
   (setvar 'peditaccept 1)
   (if el
       (setq ss (ssadd))
       (foreach l el
         (ssadd l ss)
       (command "_.PEDIT" "_M" ss "" "_J")
   (setvar 'peditaccept pea)
 (vl-load-com)
 (while
   (and
     pt
     (setq opt (cons pt opt))
     (not (initget 128))
     (setq ptt (getpoint pt "\nSpecify next point or - F8 for orthomode [Angle line/Undo] : "))
     (setq opt (cons ptt opt))
   (cond
     ( (eq (type ptt) 'list)
       (initget 2)
       (setq el (cons (entlast) el))
       (setq pt ptt)
     ( (or (wcmatch ptt "a*") (wcmatch ptt "A*"))
       (while
         (or
       (initget 1)
       (setq ptw (trans (getvar 'lastpoint) 1 0))
       (setq pt (trans ptw 0 1))
     ( (or (wcmatch ptt "u*") (wcmatch ptt "U*"))
       (if (eq (length opt) 2)
         (setq pt nil)
           (if (equal (cadr opt) (cadddr opt) 1e-
             (setq opt (cddddr opt))
             (setq opt (cddr opt))
           (if (null opt)
             (setq pt nil)
               (command "_.UNDO" "")
               (setq el (cdr el))
               (setq pt (cadr opt))
     ( (eq (type ptt) 'str)
 (*error* nil)
Regards, M.R.
P.S. You must pracitce to get used with them...
