eric_monceaux Posted December 31, 2014 Share Posted December 31, 2014 I have a simple LISP routine that I use that creates two lines offset from a center line and puts them on a specific layer. One minor minor headache that I would love to have automated is after the creation of the lines is that they would trim and extend to the nearest object. Is something like that possible? I have included a screenshot of the current output and desired output. Thanks in advance everyone! (defun c:MJ8 (/ #Entlast) (setq #Entlast (entlast)) (command "_.mline" "_st" "Standard" "_s" 0.375 "_j" "_z") (while (> (getvar 'cmdactive) 0) (princ "\nSpecify next point: ") (command PAUSE) ) ;_ while (and (not (eq #Entlast (entlast))) (or (tblsearch "layer" "03-JOINT") (alert "03-JOINT layer does not exist!")) (progn (command "_.change" (entlast) "" "_p" "_la" "03-JOINT" "") (command "_.explode" (entlast)) ) ;_ progn ) ;_ and (princ) ) ;_ defun Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 31, 2014 Share Posted December 31, 2014 This is a possible answer via lisp you pick the two cnr points you can then do a little window search and find the other 4 lines (ssget), now make your two lines but remember the two lines as objects (entlast) then its a case of trim/extend using the object collection. I do some auto multiple fillets so I know the method should work for trim also, sorry dont have code. Will see if I can find time if others do not do it first. 1 Quote Link to comment Share on other sites More sharing options...
