Antas Posted December 30, 2014 Posted December 30, 2014 Hi somebody please help me with a lisp program, which changes the layer of all tags in an attribute block into single layer selected by the user. Quote
Tharwat Posted December 30, 2014 Posted December 30, 2014 Hi , Are you aware of the command battman ? If that does not help , give more details about your goal with a sample drawing if possible . Quote
Antas Posted December 30, 2014 Author Posted December 30, 2014 Thanks for your reply. Ya I’ve used BATTMAN command a couple of times. Using that command I can change the layer of each tags of the attribute block. But with that command we can change the layers only by selecting each tag individually. Hence if I have an attribute block with many tags, it becomes tedious. But my goal is changing the layer of all tags of an attribute block into a common layer. Quote
pBe Posted December 30, 2014 Posted December 30, 2014 Ya I’ve used BATTMAN command...... ...But my goal is changing the layer of all tags of an attribute block into a common layer. You can however use block editor to change the layers of the tags then run Attsync. Let me ask you this, Are the layers for the attribute definition varies for every drawing session? or is it a permanent layer for ALL? Quote
Antas Posted December 30, 2014 Author Posted December 30, 2014 Hi pBe, I'm looking for the LISP because, this is a part of an automation process that i'm trying now. Yes the layers of Attribute definition Varies for every drawing session. But in about 70% of sessions it is a single layer "Note-ref" Quote
pBe Posted December 30, 2014 Posted December 30, 2014 Hi pBe,I'm looking for the LISP because, this is a part of an automation process that i'm trying now. By automation process you mean by batch? or are you opening the file one by one? Yes the layers of Attribute definition Varies for every drawing session. But in about 70% of sessions it is a single layer "Note-ref" And what of the 30%? how does that come into play? A lisp routine for this is easy, i'm just trying to understand the logic behind it Antas, I'm pretty sure somebody is writing a code for this as of this writing. I'm just making sure i understand all the conditions before i even start to write the lisp code Quote
Antas Posted December 30, 2014 Author Posted December 30, 2014 Thanks for your interest pBe, Let me explain my routine, I have many sets of drawings, each set contains about 20 drawings. Each drawing contains an Attribute block. That block usually contains up to 30 tags. I open one drawing, and then I change the layer of all the tags of the block into single required layer by using BATTMAN or simply by double clicking the block. 70% means… In 7 out of 10 sets I work with, needs a layer change into a layer “Note-ref". I.e all the tags of the block is converted into “Note-ref” in most drawings. Leave alone these percentages, I hope i have clarified you. Please ask if have to give any further info Quote
Tharwat Posted December 31, 2014 Posted December 31, 2014 Hi , Give this a shot and let me know (defun c:Test (/ _doc ss name l) ;;; Tharwat 31.12.2014 ;; (if (and (or (tblsearch "LAYER" "Note-ref") (progn (alert "Layer name < Note-ref > is not found in the drawing !!" ) nil ) ) (princ "\n Select Attributed Blocks ...") (ssget "_:L" '((0 . "INSERT") (66 . 1))) ) (progn (setq _doc (vla-get-ActiveDocument (vlax-get-acad-object))) (vlax-for s (setq ss (vla-get-ActiveSelectionSet _doc)) (if (not (member (setq name (vla-get-effectivename s)) l)) (setq l (cons name l)) ) ) (vla-startUndomark _doc) (vlax-for x (vla-get-blocks _doc) (if (member (vla-get-name x) l) (vlax-for b x (vla-put-layer b "Note-ref") ) ) ) (mapcar '(lambda (n) (command "_.attsync" "_name" n)) l) (vla-endundomark _doc) (if ss (vla-delete ss) ) ) ) (princ) )(vl-load-com) Quote
Antas Posted December 31, 2014 Author Posted December 31, 2014 This code is working nice, Tharwat Could you make the code to ask the user to select the layer from the available layers in the drawing.? Quote
Tharwat Posted December 31, 2014 Posted December 31, 2014 This code is working nice, Tharwat Could you make the code to ask the user to select the layer from the available layers in the drawing.? Try this and let me know . (defun c:Test (/ *error* _dialog cho _doc dlg ss name l lay) ;;; Tharwat 31.12.2014 ;; (defun *error* (msg) (if (and dlg (findfile dlg)) (vl-file-delete dlg) ) (if cho (setvar 'CMDECHO cho) ) (if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\n** Error: " msg " **")) ) (princ) ) ;;; ;;; (defun _dialog (/ nm id f l lay layers) (cond ((not (and (setq dlg (vl-filename-mktemp nil nil ".dcl")) (setq f (open dlg "w")) (write-line "options : dialog {label = \"Layers\"; height = 6; spacer_1 ; : popup_list { key = \"lst\";} : boxed_row { : button { label = \"Okay\"; key = \"oki\"; width = 12;} : button { label = \"Exit\"; key = \"esc\"; is_default = true; is_cancel = true; width = 12;}}}" f ) (not (close f)) ) ) (alert "Can't load the temporary file <!>") ) ((or (not dlg) (not (> (setq id (load_dialog dlg)) 0)) (not (new_dialog "options" id ) ) ) (princ "\n Can not load Dialog !") ) (t (while (setq l (tblnext "LAYER" (not l))) (if (not (wcmatch (setq nm (cdr (assoc 2 l))) "*|*")) (setq layers (cons nm layers)) ) ) (setq layers (acad_strlsort layers)) (start_list "lst") (mapcar 'add_list layers) (end_list) (action_tile "oki" "(setq lay (get_tile \"lst\"))(done_dialog)" ) (action_tile "esc" "(done_dialog)") (start_dialog) (unload_dialog id) (vl-file-delete dlg) ) ) (if lay (nth (atoi lay) layers) ) ) ;; ;;; (if (and (setq lay (_dialog)) (princ "\n Select Attributed Blocks ...") (ssget "_:L" '((0 . "INSERT") (66 . 1))) ) (progn (setq cho (getvar 'CMDECHO) _doc (vla-get-ActiveDocument (vlax-get-acad-object)) ) (setvar 'CMDECHO 0) (vlax-for s (setq ss (vla-get-ActiveSelectionSet _doc)) (if (not (member (setq name (vla-get-effectivename s)) l)) (setq l (cons name l)) ) ) (vla-startUndomark _doc) (vlax-for x (vla-get-blocks _doc) (if (member (vla-get-name x) l) (vlax-for b x (vla-put-layer b lay) ) ) ) (mapcar '(lambda (n) (command "_.attsync" "_name" n)) l) (vla-endundomark _doc) (setvar 'CMDECHO cho) (if ss (vla-delete ss) ) ) ) (princ) )(vl-load-com) Quote
Antas Posted December 31, 2014 Author Posted December 31, 2014 Well, you just made my 2 tedious works into an easy one. I never thought it is easy. But u simply solve it. From now i'm your fan Tharwat :thumbsup: Quote
Tharwat Posted December 31, 2014 Posted December 31, 2014 Well,you just made my 2 tedious works into an easy one. I never thought it is easy. But u simply solve it. From now i'm your fan Tharwat :thumbsup: Thanks for the nice words Antas Quote
