DataLinkQ Posted December 30, 2014 Share Posted December 30, 2014 Hi everyone, Setup; OS: Win 7 Pro X64 Product: AutoCAD 2015 Electrical CPU: i7 Graphics: AMD FirePro M6100 FireGL V Ram: 16GB Problem; I've created a datalink table to an Excel spreadsheet, and I'm only having issues with tables that required a break (table wrapping). Once I break the table and setup text properties; text height, alignment, headers, cell widths. Everything looks okay until I close and open the drawing. The first half of the table remembers the settings, but the second half always reverts back to .5 text height and top center alignment (headers and cell width are still in place on the 2nd part of the table) Solutions I've tried; I've tried to do the formatting before I break the table, I've tried after its broken. I right clicked on the tables and "Remove All Property Overrides" which makes the text all crazy, so I setup text properties, qsave and close. once I open the drawing text height and alignment changes again. If I try to "Remove All Property Overrides" the text doesn't change, so I think that function worked correctly. Summary; How can I get the 2nd half of the datalinked table to remember all property settings? I'm out of ideas Does anyone have some other solutions to try? Thanks for your time. -DataLinkQ Quote Link to comment Share on other sites More sharing options...
Ski_Me Posted December 30, 2014 Share Posted December 30, 2014 Once you break the table the external link for the part you break is severed. While the text will remain the formatting is gone. I did the same thing and had the same result as you. I just created a new second table and imported it. But the amount of data I had in the table was not very much you situation maybe very different from mine. Quote Link to comment Share on other sites More sharing options...
DataLinkQ Posted December 31, 2014 Author Share Posted December 31, 2014 Thanks for your reply. I might have to do the bigger tables separately if there isn't a way to force the formatting. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted December 31, 2014 Share Posted December 31, 2014 I do most of my formatting in Excel. Would that be possible in your situation? Quote Link to comment Share on other sites More sharing options...
DataLinkQ Posted December 31, 2014 Author Share Posted December 31, 2014 Hey RobDraw, Yes I've tried that, but the 2nd half still forgets its property settings. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted December 31, 2014 Share Posted December 31, 2014 I'm not familiar with table breaking and didn't fully understand your OP at first. Has that ever worked for you? How about setting up named ranges in the Excel file? Quote Link to comment Share on other sites More sharing options...
DataLinkQ Posted December 31, 2014 Author Share Posted December 31, 2014 No, this is my first time trying this feature. I have a BOM, and when its too long to fit in the title block, you can resize it, smaller; as you resize the table auto-breaks into 2 tables so you. when you highlight either table, both tables highlight as if it was 1 entity. in order to break the table, you just need drag the re-size arrow on the bottom of the table. Starting to think its a bug. Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 31, 2014 Share Posted December 31, 2014 Are you doing this in AutoCAD Electrical or plain AutoCAD? Quote Link to comment Share on other sites More sharing options...
DataLinkQ Posted January 6, 2015 Author Share Posted January 6, 2015 ReMark, AutoCAD Electrical. Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 6, 2015 Share Posted January 6, 2015 ReMark, AutoCAD Electrical. Why aren't you using the built-in REPORT feature then? Quote Link to comment Share on other sites More sharing options...
DataLinkQ Posted January 7, 2015 Author Share Posted January 7, 2015 Daily changes to big lists is easier to manage with excel spreadsheet rather than a feature that requires lots of preparation. Also, REPORT cannot sort by tags. Quote Link to comment Share on other sites More sharing options...
HectoCAD Posted April 6, 2019 Share Posted April 6, 2019 Hi DataLinkQ, Quote The first half of the table remembers the settings, but the second half always reverts back to .5 text height and top center alignment (headers and cell width are still in place on the 2nd part of the table) What is happening is that AutoCAD resets all formatting you do to DATA cells after the table-break. The solution is to format the table style settings. Follow these steps: 1. Type TABLESTYLE the Table Style dialog should pop up. 3. Select the table style you are using then click Modify. 4. Make sure Data is selected on the Cell Styles. 5. Under the General Tab select your desired alignment and margins 6. Under the Text Tab select your text style and text height. 7. When you're done click OK, then Close. 8. Save your drawing and close. 9. Open your drawing and the table format should remain. - Cheers! Quote Link to comment Share on other sites More sharing options...
