ok I've tried everything.... I right click in the toolbar area and get the complete list of toolbars *'Checked'* and I only have a few displayed... I uncheck and recheck and I get nothing. there is a command (a variable even) that I can get them all to float so I can put wherever but I don't remember it. (did it at work)
funny that.... I found my tool bars... on my desktop on my other monitor. wasn't even looking over there... :unsure::oops:
.... there is a command (a variable even) that I can get them all to float so I can put wherever
Presuming that was a question, and you need it in the future...
Run the command -TOOLBAR (note the leading hyphen).
Then enter the toolbar name, then Float, and follow the prompts.
-or-
Even with no toolbars showing, if you have the Ribbon enabled, on the View tab is this...
We have right hand left handed staff at work ! Unfortunately the 3rd party software we use remembers which screen its on with dual screens only problem is if you open some one elses dwg and do certain commands the new screen that pops is behind the current Autocad session took a while to find it I use left the other used right screen, easy now minimise acad move new screen to other screen.
