MaxwellEdison Posted December 15, 2008 Share Posted December 15, 2008 Let the internets teach you! http://www.we-r-here.com/cad/tutorials/level_3/3-7a.htm Quote Link to comment Share on other sites More sharing options...
spursnutter Posted December 15, 2008 Author Share Posted December 15, 2008 Does it cover 09? Quote Link to comment Share on other sites More sharing options...
MaxwellEdison Posted December 15, 2008 Share Posted December 15, 2008 The commands don't operate that differently from what I've seen. If you can't find them on the ribbon, the command line entry should still work. Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 16, 2008 Share Posted December 16, 2008 spurs: If I draw a 90 deg bend then extrude a circle along this path, don't I get the same result as your multi-step approach? Quote Link to comment Share on other sites More sharing options...
shift1313 Posted December 16, 2008 Share Posted December 16, 2008 loft is very simple to use. you just need multiple cross section you want to loft through. For example if you drew one circle 70mm dia and another that was 200mm away in the Z axis that was 100mm dia and used LOFT, you select these (in order, matters when you have more than 2) and you will have an object or surface(depending on the options you choose) that will go from the smaller circle to the larger. There are also guide curves you can use to modify how you want the loft to be performed. Sweep is very helpful as well as you can create complex curves using spline and sweep your circle cross section along that "path". I tried to read back through the post but i got a little lost. Did you figure out what you were asking? The first post mentioned using fillet, which will not work in this case as far as i know. If i were to draw that shape i would draw a path and sweep or extrude path. If you need a different radius inside and outside of the bend you can use sweep or loft and have guide curves(i cant remember if sweep allows guide curves at the moment). Quote Link to comment Share on other sites More sharing options...
spursnutter Posted December 16, 2008 Author Share Posted December 16, 2008 loft is very simple to use. you just need multiple cross section you want to loft through. For example if you drew one circle 70mm dia and another that was 200mm away in the Z axis that was 100mm dia and used LOFT, you select these (in order, matters when you have more than 2) and you will have an object or surface(depending on the options you choose) that will go from the smaller circle to the larger. There are also guide curves you can use to modify how you want the loft to be performed. Sweep is very helpful as well as you can create complex curves using spline and sweep your circle cross section along that "path". I tried to read back through the post but i got a little lost. Did you figure out what you were asking? The first post mentioned using fillet, which will not work in this case as far as i know. If i were to draw that shape i would draw a path and sweep or extrude path. If you need a different radius inside and outside of the bend you can use sweep or loft and have guide curves(i cant remember if sweep allows guide curves at the moment). Yes all I was asking if it was possible with the fillet tool. I really need to learn the loft tool. Quote Link to comment Share on other sites More sharing options...
