I can't seem to figure out how to load ArxDBG....
I'm sorry but that didn't help at all.
I can't seem to net load it, and I cant seem to app load it.
I do not know what you mean be a .bundle or an arxload.
I have searched for anything in the C:\ObjectARX 2015\samples\database\ARXDBG folder for an object to load. I can't find any.
If you do not understand the difference between NETLOAD and ARXLOAD, you shouldn't be messing with ArxDbg, or MgdDbg, frankly... Look the capitalized words up in the help, as a starting point.
Once you've learned the difference between these two you might begin to tackle the Autoloader mechanism (i.e., .bundles).
Good luck!
  • 7 months later...
probably you dont have the right ARXDGB file. You can download it from the below link.
http://otb.manusoft.com/2009/09/arxdbg-utility.htm
thanks to OWEN WENGERD who shared this.
i think it is a good thing that you are trying. You dont know the difference now but you will learn it by messing around with it.
