joseantonio Posted December 12, 2014 Posted December 12, 2014 I need to change the attribute of "tag" = "PRO" in all blocks of the model space of the active document in autocad. The text you need to add is "my project". I searched for information about walking blocks and change the attributes but I get nothing. Can anyone help me please? Quote
BlackBox Posted December 12, 2014 Posted December 12, 2014 Welcome to CADTutor! Once you've obtained the desired BlockTableRecord, simply iterate GetBlockReferenceIds(), opening each BlockReference and edit the Attribute as needed... Here are some articles that may help: Identify the number of reference to a block Updating a specific attribute inside an AutoCAD drawing using .NET Edit Attribute Definitions Cheers Quote
joseantonio Posted December 12, 2014 Author Posted December 12, 2014 thank you very much. I am going to read them. Quote
BIGAL Posted December 13, 2014 Posted December 13, 2014 Here is some examples to get you started Public Sub ModifyPitSchedule1() ' adds single pt Dim SS As AcadSelectionSet Dim objENT As AcadEntity Dim Count, Cntr As Integer Dim Newpitname As String Dim pitname As String Dim FilterDXFCode(0) As Integer Dim FilterDXFVal(0) As Variant Dim PitNameSelect As AcadObject Dim basepnt, pt1, pt2, pt3 As Variant Dim attribs As Variant 'On Error Resume Next Newpitname = "1" 'dummy to pass then return changed BLOCK_NAME = "SCHEDTEXT" pitname = Getpitname(Newpitname) MsgBox "pitname selected is " & pitname FilterDXFCode(0) = 0 FilterDXFVal(0) = "INSERT" 'FilterDXFCode(1) = 2 'FilterDXFVal(1) = "SCHEDTEXT" Set SS = ThisDrawing.SelectionSets.Add("pit1sel") SS.Select acSelectionSetAll, , , FilterDXFCode, FilterDXFVal For Cntr = 0 To SS.Count - 1 If SS.Item(Cntr).Name = BLOCK_NAME Then attribs = SS.Item(Cntr).GetAttributes If attribs(0).TextString = pitname Then pt1 = ThisDrawing.Utility.GetPoint(, " pick first point") txtx1 = CStr(FormatNumber(pt1(0), 3)) TXTY1 = CStr(FormatNumber(pt1(1), 3)) attribs(1).TextString = txtx1 attribs(2).TextString = TXTY1 attribs(1).Update attribs(2).Update ' ThisDrawing.Application.Update ' try this Cntr = SS.Count Else: End If Else: End If Next Cntr ThisDrawing.SelectionSets.Item("pit1sel").Delete End Sub This one allows either a text as the name of the attribute or pick a block Function Getpitname(Newpitname As String) As String Dim PitNameSelect As AcadObject Dim pitattribs As Variant ThisDrawing.Utility.GetEntity PitNameSelect, basepnt, "pick pit name : " If PitNameSelect.ObjectName = "AcDbText" Then Getpitname = PitNameSelect.TextString End If If PitNameSelect.ObjectName = "AcDbBlockReference" Then pitblname = PitNameSelect.Name ' RETURNS BLOCK NAME pitattribs = PitNameSelect.GetAttributes Getpitname = pitattribs(0).TextString End If End Function Quote
