A start for you maybe have a go at writing a lisp using vl you can get co-ords of plines and their elevation
(vl-load-com)
(setq obj1 (vlax-ename->vla-object (car (entsel "\npick pline"))))
(setq coords (vlax-safearray->list (vlax-variant-value(vla-get-coordinates obj1)))) ; 1st 2 variables are start last 2 are end pt
(setq ht (vla-get-elevation obj1)) ; height of pline
[code]
i have got it already lisp file but in this lisp file little be mistake. this file was generate only start edge. i need generated with Polyline both of side edge.
(defun C:MCL ()
(setq ss (ssget'((0 . "LWPOLYLINE"))))
(setq sslngth (sslength ss))
(Setq idx 0)
(repeat sslngth
(setq ename (ssname ss (setq sslngth (1- sslngth))))
(setq edata (entget ename))
(setq xy (cdr (Assoc 38 edata)))
(setq xy1(cdr (Assoc 10 edata)))
(setq xx(rtos xy 2 3))
(command "text" xy1 2 30 xx "")
Try..
(defun c:test (/ ss i ed p [color="red"]sz[/color])
[color="red"](initget 6)
(if (not(setq sz (getdist "\nText size : ")))
(setq sz (getvar "textsize")))[/color]
 (prompt "\nSelect Contour.. ")
 (if (setq ss (ssget ":L" '((0 . "LWPOLYLINE"))))
     (setq ed (entget (ssname ss (setq i (1- i)))))
     (foreach x (list (car (setq p (vl-remove-if ''((x) (/= (car x) 10)) ed))) (last p))
(entmakex (list	'(0 . "TEXT")'(8 . "CONTOUR LABEL")
		(cons 1 (rtos (cdr (assoc 38 ed)) 2 3))
		(cons 40[color="red"] sz[/color])
		x
		) ;_ end of list
	  ) ;_ end of entmakex
) ;_ end of foreach
     ) ;_ end of repeat
   ) ;_ end of if
 ) ;_ end of defun
i hope BIGAL can understand im online now to help OP
Edited by hanhphuc
textsize
can you make changes in LISP. For example set text height, "2" and select polyline or spline
#5 updated (in red)
you can set default,
command: textsize
sir can you give me last time changes in the lisp file? i want to label generate the single time at closest Polyline.
