wileyhk2001 Posted December 10, 2014 Posted December 10, 2014 (edited) Dear all, I just switched workplace with one of my colleague and she had been using a Chinese version of Autocad. How do I switch it back to English? I searched in the startup menu for "AutoCad 2013 - English" but it was no where to be found. I certainly don't want to go into all the hustle of finding the original installation disk or anything like that.. Please advice. Edited December 10, 2014 by wileyhk2001 Quote
edwinprakoso Posted December 10, 2014 Posted December 10, 2014 I've never tried this before, but I believe you can solve this by installing English language pack. Download it from here: http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autocad-2013-language-packs.html Then install it. Quote
RobDraw Posted December 10, 2014 Posted December 10, 2014 http://adndevblog.typepad.com/autocad/2013/04/switch-language-of-autocad-2014-without-installing-multi-copy.html Quote
Patrick Hughes Posted December 10, 2014 Posted December 10, 2014 You may be able to control the language via shortcut startup switches. http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Startup-switches-for-AutoCAD.html Edit: I should read other replies more often. Quote
wileyhk2001 Posted January 6, 2015 Author Posted January 6, 2015 This solved my problem! thanks! Quote
Murali_krishna Posted November 6, 2019 Posted November 6, 2019 How did u do it. I am facing the same problem. Quote
Cad64 Posted November 6, 2019 Posted November 6, 2019 On 11/6/2019 at 1:05 AM, Murali_krishna said: How did u do it. I am facing the same problem. As mentioned previously in this thread, you need to install the language pack for your preferred language. Your profile says you're running 2020, so take a look HERE. Quote
Ashk Posted August 15, 2023 Posted August 15, 2023 I downloaded the language package according to my Autocad version. But I am facing problems. When I tried to install it, it showed that one of the files had been downloaded before downloading the package. And it showing the error. Quote
Norge Posted November 17, 2024 Posted November 17, 2024 Hi guys I need to find the English Language package for AutoCAD 2017. Does anyone have it? Quote
