sacprasanna Posted December 5, 2014 Share Posted December 5, 2014 Hello all, I created points on an Alignment by Importing ASCII File.(Station, Offset, Elevation format).Like this, 0,-10,104.003 0,-6.7,104.015 0,-4,104.026 0,-1.5,104.045 0,0,104.007 0,2,104.041 0,4.7,104.102 0,8.7,104.152 0,9,104.168 10,-5.6,103.629 10,-4.3,103.598 10,-4,103.449 10,-3.5,103.345 10,-1.4,103.426 10,0,103.463 10,1.7,103.448 10,3.2,103.314 10,7.5,103.29 20,-4.6,103.203 20,-3.8,103.15 20,-3.4,103.076 20,-3,103.097 20,-2.45,103.238 20,-1,103.255 20,0,103.259 20,3.6,103.172 20,4,103.265 Then using surface and sample lines cross sections are generated. They I need to add above points (those are at ASCII file) elevations and offsets to the section view as data bands. But I can't figure out how to do it.I can only add elevations at regular intervals. Really appreciate any help. Thanks. Chamara Prasanna AutoCAD Civil 3D 2015 SP 1 Sri Lanka Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 5, 2014 Share Posted December 5, 2014 Please post image "DATA BANDS" not sure what you mean. Quote Link to comment Share on other sites More sharing options...
sacprasanna Posted December 5, 2014 Author Share Posted December 5, 2014 Hello BIGAL, I attached the image. Need to add elevations and offset of red circled points. Thanks for reply. Chamara 1 Quote Link to comment Share on other sites More sharing options...
adrath Posted December 9, 2014 Share Posted December 9, 2014 If you brought the points in as COGO points, you should be able to project them to your section view group so that they show up in all of the sections along a given alignment. Then you can create a label style that shows offset/elevation, label all points through the section view properties and just drag the labels down so that they appear to be part of the band. There may be an easier way, but I think that's probably the general workflow to accomplish what you're looking for. Quote Link to comment Share on other sites More sharing options...
geoneo Posted August 28, 2018 Share Posted August 28, 2018 On 12/5/2014 at 9:02 AM, sacprasanna said: Hello BIGAL, I attached the image. Need to add elevations and offset of red circled points. Thanks for reply. Chamara In Section View Properties put the "Weeding" = 0 and you will see the elevations and offset of red circled points. If you want elevations and offset of red circled points ONLY, without any other points, put "Minnor and Major Interval" a big number, perhaps greater than the width of section e.g. 500.00m. Quote Link to comment Share on other sites More sharing options...
