eric_monceaux Posted December 4, 2014 Posted December 4, 2014 Hello Everyone! I have a simple dynamic block to use for call-outs (see DYN-REC-TEST.DWG) It is adjustable by one point, but I wanted to see if there was a way to dynamically change the radius corners for smaller or larger call outs (i.e. DETAIL SECTIONS and PLAN VIEWS). Currently I just scale the block up or down to achieve the desired size. Also, second issue. I want to make sure this titleblock scales uniformly based on viewport scale. Can I use the Scale action to set various sizes for the block (i.e. DIMSCALE: 8, 16, 32, 64)? I have included the block (DWG_TTL_BUILD.DWG) if needed. DYN-REC-TEST.dwgFetching info... DWG-TTL-BUILD.dwgFetching info... Quote
