Sengna Posted December 3, 2014 Posted December 3, 2014 this is my first experience using array rectangle command in autocad 2014, i noticed that the objects had grouped or similar to block. How can i edit one of the stud but not effect the others. ex: i want to move the bottom stud 2" down but i don't want the rest above to move, what is the trick to do that? thanks Quote
BIGAL Posted December 3, 2014 Posted December 3, 2014 Arrayassoiciativity set to 0 and it will make arrays as individual objets or explode array once Quote
rkent Posted December 3, 2014 Posted December 3, 2014 (edited) Keep the associativity, with nothing selected, hold control down and select the one to move, drag it in place. Edited December 3, 2014 by rkent Quote
Sengna Posted December 3, 2014 Author Posted December 3, 2014 Arrayassoiciativity set to 0 and it will make arrays as individual objets or explode array once I set Arrayassoiciativity to 0, the objects are still grouped. Wierd Quote
Sengna Posted December 3, 2014 Author Posted December 3, 2014 Keep the associativity, with nothing selected, hold control down and select the one to move, drag it in place. Awesome, This method works for me Thanks alot. Quote
BIGAL Posted December 3, 2014 Posted December 3, 2014 Arrayassoiciativity set to 0 was a guess normally 0 is the equivalent to OFF. Quote
