I'm not sure but I assume this is simple, I want to create a new .txt file from a lisp routine. Can this be done? I have searched the internet and these forums and can't find anything at all on how to create a file. Everything just tells you how to write to an existing file
Thanks in advance.
In its simplest form:
(setq des (open "C:\\MyTextFile.txt" "w"))
(write-line "This is a test." des)
(close des)
And a slightly more elaborate example:
(defun c:writetextfile ( / des txt ) ;; Define function, declare local variables
   (if (setq txt (getfiled "Create Text File" "" "txt" 1)) ;; Prompt user for filename/filepath
       (if (setq des (open txt "w")) ;; Attempt to create text file with given filename/filepath
           (progn ;; Evaluate the enclose expressions as the 'then' expression for the IF statement
               (write-line "This is a test." des) ;; Write line of text to text file
               (close des) ;; Close file descriptor
           ) ;; end PROGN
           (princ "\nUnable to create text file.") ;; Else the text file could not be created
       ) ;; end IF
       (princ "\n*Cancel*") ;; Else the user pressed Cancel
   ) ;; end IF
   (princ) ;; Suppress the return of the last evaluated expression
) ;; end DEFUN
Ok, thanks for that. It appears I am doing it correctly but it doesn't work
(setq StrRx (open "C:\\WCcharset.txt" "w"))
(write-line p+ StrRx)
(close StrRx)
THis is my code. My code works if I manually create the file already, but as soon as I delete the file from my hard drive, it doesn't work and i get an error.
Any thoughts?
I thought it might be to do with permissions but I made sure my security settings on c drive allowed full access.
Really stumped
Ok, it was a permissions thing. No mater how much full control i gave myself of c drive I still didn't have enough permissions to create a file, even manually. Got to love Windows.
Yes, as shown in my second example above, you'll need to include error trapping to ensure that a valid file descriptor is returned before attempting to write to it & close it, e.g.:
(if (setq des (open "C:\\test.txt" "w"))
       (write-line "testing" des)
       (close des)
   (princ "\nUnable to create/modify test.txt.")
