iyant Posted November 27, 2014 Posted November 27, 2014 need help how do I export the data points XY of CAD using LISP into excel file for example XY.xls and placed into a specific cell sheet, eg X = Y = cell cell c2 d2 thank you Quote
hanhphuc Posted December 3, 2014 Posted December 3, 2014 (edited) iyant said: need help how do I export the data points XY of CAD using LISP into excel file for example XY.xls and placed into a specific cell sheet, eg X = Y = cell cell c2 d2 thank you The easiest way is to save as *.csv comma seperated format then open with excel example: ;V1.1: 04/12/2014 ;PXYZ test.csv saved to dwgprefix ;add numbering PXYZ format ;index i 1+ incremental ;notified by alert ;optional: add Text numbering ;optional: open notepad ;optional: open directory (vl-load-com) (defun c:P2F ( / *error* p i ss fn pt ) ;hanhphuc 2014 (defun *error* (msg) (if (not (wcmatch (strcase msg) "*CANCEL*,*EXIT*")) (princ (strcat "\nError: " msg)) ) (if p (close p) ) (princ) ) (if (and (setq i 0 ss (ssget ":L" '((0 . "POINT"))) ) (setq fn (strcat (getvar "dwgprefix") "PXYZ test.csv") ; rename you file ) (setq p (open fn "w")) ) (progn ;(setq i 0) (repeat (sslength ss) ( (lambda (str) (foreach x (setq pt (vlax-get (vlax-ename->vla-object (ssname ss i)) 'coordinates ) ) (setq str (strcat str (rtos x 2) ",")) ) (write-line (strcat (itoa (setq i (1+ i))) "," str) p) ) "" ) (entmakex (list '(0 . "TEXT") (cons 1 (itoa i)) (cons 10 pt) (8 . "EXPORTED") (cons 40 (getvar 'TEXTSIZE)) ) ) ) (if p (close p) ) (alert (strcat "\nSyabas! Saved in \"" fn ;"\"\nOK -> \"PXYZ test.csv\" -> Right-Click -> Open With -> EXCEL" ) ) ;;;(command "_SHELL" (strcat "explorer \"" (getvar "dwgprefix") "\"")) ;<-- optional (vl-cmdf "_START" (strcat "EXCEL \"" fn "\"")) (startapp "notepad" fn) ;; <--optional open as notepad preview ) (alert "\n:-( knp xde POINT ?! ") ) (princ) ) As i notice if you are using Land Desktop, not sure this works in LDD? why not using utility export point? try look at LDD forum HTH Edited April 2, 2020 by hanhphuc color tags removed Quote
stevesfr Posted December 3, 2014 Posted December 3, 2014 The easiest way is to save as *.csv comma seperated format then open with excel example: (defun c:TEST (/ *error* p i ss fn) ;hanhphuc 2014 (defun *error* (msg) (if (not (wcmatch (strcase msg) "*CANCEL*,*EXIT*")) (princ (strcat "\nError: " msg)) ) ;_ end of if (if p (close p) ) ;_ end of if (princ) ) ;_ end of defun (if (setq ss (ssget ":L" '((0 . "POINT")))) (progn (setq p (open (setq fn [color="red"](strcat (getvar "tempprefix") "XY test.csv")[/color])"w")) ; you can change file name (repeat (setq i (sslength ss)) ((lambda (str) (foreach x (vlax-get (vlax-ename->vla-object (ssname ss (setq i (1- i)))) 'coordinates) (setq str (strcat str (rtos x) ",")) ) ;_ end of foreach (write-line str p) ) ;_ end of lambda "" ) ) ;_ end of repeat ) ;_ end of progn ) ;_ end of if (close p) (alert (strcat "\nSaved in "fn)) ; <-- notify file name (princ) ) ;_ end of defun As i notice if you are using Land Desktop, not sure this works in LDD? why not using utility export point? try look at LDD forum HTH using AC2008 I get the following error from the program: Select objects: Error: ActiveX Server returned the error: unknown name: "COORDINATES" I believe this is a bug somehow undefined ? or is it not available in AC2008? Quote
Tharwat Posted December 3, 2014 Posted December 3, 2014 returned the error: unknown name: "COORDINATES" Try to add (vl-load-com) to the program and test it again . Quote
stevesfr Posted December 3, 2014 Posted December 3, 2014 Try to add (vl-load-com) to the program and test it again . Tharewat, thanks for the reply, but adding (vl-load-com) did not help the program to execute. Perhaps others have had success while I am doing something wrong. Quote
JSYoung81 Posted December 3, 2014 Posted December 3, 2014 (DEFUN C:Exportpnt (/ FILE FILENAME ANS CNT PT X Y Z LINE DESC LINECOUNTER LINEDATA LEN OSM ) (SETQ OSM (GETVAR "OSMODE")) (COMMAND "OSMODE" 0) ;; ;; THIS WILL SET THE FILE NAME WE ARE WRITTING TO AS WELL AS CHECK ;; TO MAKE SURE THAT WE ARE WRITTING AT THE END OF THE FILE ;; (SETQ LINECOUNTER 0) (SETQ FILE (GETSTRING "\nNAME OF POINTS FILE TO OPEN:...")) (SETQ FILENAME (OPEN FILE "A")) (CLOSE FILENAME) (SETQ FILENAME (OPEN FILE "R")) (WHILE (SETQ LINEDATA (READ-LINE FILENAME)) (SETQ LEN (STRLEN LINEDATA)) (SETQ LINECOUNTER (+ 1 LINECOUNTER)) ) (CLOSE FILENAME) (SETQ FILENAME (OPEN FILE "A")) (INITGET "Yy Nn") (SETQ ANS (GETKWORD "\n ADD DESCRIPTIONS? Yes OR No ?:...") CNT (GETINT "\nENTER NUMBER OF POINTS TO EXPORT:...") PT (GETPOINT "\nSELECT POINT TO EXTRACT:....") ) ;; ;; THIS BEGINS THE REPEAT LOOP TO EXTRACT THE POINT INFORMATION ;; (REPEAT CNT (IF ( = ANS "Yy") (SETQ DESC (GETSTRING "\nENTER DESCRIPTION:...")) ) (SETQ X (RTOS (CAR PT)) Y (RTOS (CADR PT)) Z (RTOS (CADDR PT)) LINECOUNTER (+ 1 LINECOUNTER) ) (IF (= ANS "Yy") (SETQ LINE (STRCAT (ITOA LINECOUNTER) "," Y "," X "," Z "," DESC)) (SETQ LINE (STRCAT (ITOA LINECOUNTER) "," Y "," X "," Z)) ) (WRITE-LINE LINE FILENAME) (SETQ PT (GETPOINT "\nSELECT NEXT POINT TO EXTRACT:...")) ) ;END OF REPEAT LOOP (CLOSE FILENAME) ;; RESET THE OSNAP MODE (COMMAND "OSMODE" OSM) (PRINC) ) Will save the file in the directory of the DWG Quote
BIGAL Posted December 3, 2014 Posted December 3, 2014 The routine looks for Autocad "Points" if they are in fact LDD Points then it will probably not work, as mentioned above need different code for LDD. Quote
JSYoung81 Posted December 3, 2014 Posted December 3, 2014 The routine looks for Autocad "Points" if they are in fact LDD Points then it will probably not work, as mentioned above need different code for LDD. You just click and it will store the XY values, doesn't have to be a cogo point. Quote
Tharwat Posted December 4, 2014 Posted December 4, 2014 how do I export the data points XY of CAD using LISP into excel file for example XY.xls and placed into a specific cell sheet, eg X = Y = cell cell c2 d2 Have a go with this program and let me know . (defun c:Test (/ i s e p o f) ;; Tharwat 04.12.2014 ;; (princ "\n Select points to export coordinates to new excel file ") (if (and (setq s (ssget '((0 . "POINT")))) (setq f (getfiled "Save to " (getvar 'DWGPREFIX) "csv" 1)) (setq o (open f "w")) ) (progn (repeat 2 (write-line "" o)) (repeat (setq i (sslength s)) (setq e (entget (ssname s (setq i (1- i)))) p (cdr (assoc 10 e)) ) (write-line (strcat ";;" (rtos (car p) 2) ";" (rtos (cadr p) 2)) o ) ) (close o) ) ) (princ) ) Quote
hanhphuc Posted December 4, 2014 Posted December 4, 2014 Thanks Tharwat,BIGAL,JSYoung81,stevesfr for assisting thread very appreciated. i slept early last night Error: ActiveX Server returned the error: unknown name: "COORDINATES" sorry. missing (vl-load-com) code updated in post#2 note: this code only Exports acad AcDbPoint, NOT AECC point! The routine looks for Autocad "Points" if they are in fact LDD Points then it will probably not work, as mentioned above need different code for LDD. i came across your old thread AECC_COGO_POINT , should be different method property for LDD & C3D You just click and it will store the XY values, doesn't have to be a cogo point. hi JSYoung81 we meet again yes your code works because it just creates new incremental points, here are similar threads by Lee VVA Quote
iyant Posted January 27, 2015 Author Posted January 27, 2015 Have a go with this program and let me know . (defun c:Test (/ i s e p o f) ;; Tharwat 04.12.2014 ;; (princ "\n Select points to export coordinates to new excel file ") (if (and (setq s (ssget '((0 . "POINT")))) (setq f (getfiled "Save to " (getvar 'DWGPREFIX) "csv" 1)) (setq o (open f "w")) ) (progn (repeat 2 (write-line "" o)) (repeat (setq i (sslength s)) (setq e (entget (ssname s (setq i (1- i)))) p (cdr (assoc 10 e)) ) (write-line (strcat ";;" (rtos (car p) 2) ";" (rtos (cadr p) 2)) o ) ) (close o) ) ) (princ) ) Tharwat This code can be changed in order to automatically enter into an excel file that we have to make before? Quote
Tharwat Posted January 28, 2015 Posted January 28, 2015 I don't see any respect to reply after two months to people whom trying to help you for free . Quote
CADWORKER Posted January 29 Posted January 29 On 12/4/2014 at 7:43 AM, Tharwat said: Have a go with this program and let me know . (defun c:Test (/ i s e p o f) ;; Tharwat 04.12.2014 ;; (princ "\n Select points to export coordinates to new excel file ") (if (and (setq s (ssget '((0 . "POINT")))) (setq f (getfiled "Save to " (getvar 'DWGPREFIX) "csv" 1)) (setq o (open f "w")) ) (progn (repeat 2 (write-line "" o)) (repeat (setq i (sslength s)) (setq e (entget (ssname s (setq i (1- i)))) p (cdr (assoc 10 e)) ) (write-line (strcat ";;" (rtos (car p) 2) ";" (rtos (cadr p) 2)) o ) ) (close o) ) ) (princ) ) cad we add z "x,y,z" and layer to this code. Quote
Steven P Posted January 29 Posted January 29 Z is easy, add (rtos (caddr p) 2) to this line (strcat ";;" (rtos (car p) 2) ";" (rtos (cadr p) 2)) to be (strcat ";;" (rtos (car p) 2) ";" (rtos (cadr p) 2) ";" (rtos (caddr p) 2)) Layer you'll need to add something line (setq lay (cdr (assoc 8 e)) ) maybe in here (setq e (entget (ssname s (setq i (1- i)))) p (cdr (assoc 10 e)) lay (cdr (assoc 8 e)) ;;Layer ) and add lay into the (strcat..... ) line above like this: (strcat ";;" (rtos (car p) 2) ";" (rtos (cadr p) 2) ";" (rtos (caddr p) 2) ";" lay) 1 Quote
