toonamo Posted November 22, 2014 Posted November 22, 2014 in earlier versions of autocad osnap used to snap to all endpoints if i had it enabled. Now osnap only snaps to endpoints that would be visiable if the object was solid. If a endpoint is "through", underneath, or inside a object. I am unable to snap to it. I am using autocad 2015 does anyone know where the setting is to toggle this behavior? Quote
nestly Posted November 22, 2014 Posted November 22, 2014 Welcome to Cadtutor Most likely, it's because Dynamic UCS (UCSDETECT) is enabled, which effectively limits OSnaps to those that are on the face or surface that's being selected. Quote
Cad64 Posted November 22, 2014 Posted November 22, 2014 Try setting the variable CULLINGOBJ to 0. http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Unable-to-highlight-or-select-3D-subobjects-in-AutoCAD-2011.html Quote
