r-key-tect Posted November 18, 2014 Posted November 18, 2014 I just upgraded to AutoCAD 2015. There is no properties panel in my home tab, not there when I right-click, not in the cui - where did it go and how can I get it back? Quote
nestly Posted November 18, 2014 Posted November 18, 2014 You're probably in the ACA profile, which does not include the Properties panel. If you switch profiles to "AutoCAD" it should be there. If you want it in ACA, you can transfer it in from the acad.cuix Quote
voske Posted February 10, 2015 Posted February 10, 2015 You're probably in the ACA profile, which does not include the Properties panel. If you switch profiles to "AutoCAD" it should be there. If you want it in ACA, you can transfer it in from the acad.cuix is there a guide of some sort around about how to do this? Quote
r-key-tect Posted February 10, 2015 Author Posted February 10, 2015 Our IT guy fixed it, although I do not know how. Quote
