I am trying to open a file that I was working on a few days ago. Saved fine and now when I open it autocad acts like its opening it through a new tab up and then blows the drawing out before it fully opens with no error report.
Did you try the RECOVER command?
Is there a .BAK file available?
yes there is a .bak file. How do I use that file. New to autocad.
First I'd try to use the RECOVER command on the drawing. If that fails then find and rename the .BAK file (ex. - mydrawing.bak rename to mydrawing.dwg) then open it. Hopefully there will be enough of the drawing left to avoid having to do it all over again.
Re: RECOVER.
Start a new drawing.
Invoke the command.
Navigate to where the drawing is located and click on the drawing name then click on the Open button. Stop! Does the drawing open?
