Hi Autocad Experts,
I am new to Autocad customization using VB.net.
We have a requirement to draw a horizontal line from a given co-ordinate to the point where it intersects with any other line. It's perhaps already discussed in the forum, but since I am new to vb.net, I am not able to put things together.
Appreciate any help I can get from this forum. Looking forward to replies.
Edited by vinayds
spelling mistake
Welcome to CADTutor.
Perhaps you can share a bit about your environment, and proficiencies that might help us to help you?
What versions are you developing for, what IDE you're using, are you using .NET Wizard or custom template, how are you distributing your app, are just a few questions.
Also, please post your code... It doesn't have to be working, or even well written; just something that shows you've put in the initial effort, and precludes another from having to code it all from scratch (which saves us time to help you).
Cheers
Some theory to help, pick pt, enter bearing, pick pt as limit of search, using this "new" line you can get all crossing objects, calculate the intersection point for each and compare so you get say the closest pt or longest. Like Blackbox post code.
BLACKBOX/BIGAL:
The version I am developing for is Autocad 2012. And IDE I use is Visual Studio 2012. I intend to use command method of execution for now. I have taken snippets of code from this very forum and made some minor changes to see how it works. Below is the code: This does some things more than what I actually need. My requirement is very simple. 1. User will provide a co-ordinate, 2. Should draw (ONLY) a horizontal line from the given co-ordinate until this horizontal line meets another line or object. I am pretty new to this and hence need your support in getting this worked out. Thanks.
Imports System.Collections.Generic
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Interop
Imports System.Text.RegularExpressions
Public Class Class1
   <CommandMethod("pts")> _
   Public Sub pts()
       Dim lineCmd As Editor =
Application.DocumentManager.MdiActiveDocument.Editor
       Dim acadBaza As Database = lineCmd.Document.Database
       Dim trans As Transaction =
acadBaza.TransactionManager.StartTransaction
       Dim opPoint As PromptPointOptions = New PromptPointOptions("Click on
a Co-ordinate :")
       Dim rePoint As PromptPointResult = lineCmd.GetPoint(opPoint)
       Dim crvDict As Dictionary(Of Double, Line) = New Dictionary(Of
Double, Line)()
       ' confstruction of filter
       Dim typeValue() As TypedValue = {New TypedValue(0, "line")}
       Dim selFilter As SelectionFilter = New SelectionFilter(typeValue)
       Dim selectResult As PromptSelectionResult =
lineCmd.SelectAll(selFilter)
       If rePoint.Status = PromptStatus.OK Then
           Dim rePoint2 As Point3d = New Point3d(rePoint.Value.X + 10,
rePoint.Value.Y, 0)
           Dim prosta As Ray = New Ray()
           Dim tmpPt As Point3d
           prosta.BasePoint = rePoint.Value
           prosta.SecondPoint = rePoint2
           Try
               Dim btr As BlockTableRecord =
trans.GetObject(acadBaza.CurrentSpaceId, OpenMode.ForWrite)
               btr.AppendEntity(prosta)
               trans.AddNewlyCreatedDBObject(prosta, True)
               If selectResult.Status = PromptStatus.OK Then
                   Dim ss As SelectionSet = selectResult.Value
                   Dim idTab() As ObjectId = ss.GetObjectIds()
                   Dim ra As Ray = CType(trans.GetObject(prosta.Id,
OpenMode.ForRead), Ray)
                   Dim ptc As Point3dCollection = New
Point3dCollection()
                   Dim intthis As Integer
                   Dim intThat As Integer
                   Dim objId As ObjectId
                   Dim x As Double
                   For Each objId In idTab
                       Dim tempptc As Point3dCollection = New
Point3dCollection()
                       Dim ln As Line = CType(trans.GetObject(objId,
OpenMode.ForRead), Line)
                       ln.IntersectWith(ra, Intersect.OnBothOperands,
ln.GetPlane(), tempptc, intthis, intThat)
                       If tempptc.Count > 0 Then
                           MsgBox(tempptc.Count)
                           For Each pt As Point3d In tempptc
                               x = Math.Round(pt.X, 6)
                               crvDict.Add(x, ln) 'add line to dictionary
with X coordinate as Key
                               ptc.Add(pt)
                           Next
                       End If
                   Next
                   'trans.Commit()
                   If crvDict.Count > 0 Then
                       Dim pts As Point3d
                       tmpPt = ptc.Item(0)
                       Dim i As Integer
                       If ptc.Count > 1 Then
                           For i = 0 To ptc.Count - 1
                               pts = ptc(i)
                               If pts.X < tmpPt.X Then
                                   tmpPt = pts
                               End If
                           Next
                       End If
                       MsgBox(tmpPt.ToString)
                       Dim s As String() = Regex.Split(tmpPt.ToString,
                       Dim value1 As Double
                       Dim value2 As Double
                       Double.TryParse(s(0).Substring(1), value1)
                       Double.TryParse(s(1), value2)
                       Dim rePoint3 As Point3d = New Point3d(value1, value2,
0)
                       Dim prosta1 As Line = New Line()
                       prosta1.StartPoint = rePoint.Value
                       prosta1.EndPoint = rePoint3
                       btr.AppendEntity(prosta1)
                       trans.AddNewlyCreatedDBObject(prosta1, True)
                       MsgBox(value1)
                       MsgBox(value2)
                       trans.Commit()
                       lineCmd.WriteMessage(tmpPt.ToString)
                       crvDict(Math.Round(tmpPt.X, 6)).Highlight() 'Retrieve
line based on X coordinate Key equal to tmpPt.X
                       lineCmd.WriteMessage(" ObjectId: " &
crvDict(Math.Round(tmpPt.X, 6)).ObjectId.ToString())
                   Else
                       lineCmd.WriteMessage("No intersections")
                   End If
               End If
           Catch ex As Exception
               lineCmd.WriteMessage("There is a problem" + ex.Message)
               MsgBox(ex.Message)
           Finally
               trans.Dispose()
           End Try
       End If
   End Sub
End Class
Edited by vinayds
added code hashtag
Hi there,
I tried a set of code which seems to work to a certain extent. But, the horizontal line does not seem to stop at the first intersection. Also, there is a limitation that it only identifies another line for intersection point and not a curve or any other plane. Please help!
Public Class Class1
   <CommandMethod("dwl")> _
   Public Sub pts()
a Co-ordinate :")
           Using trans As Transaction =
acadBaza.TransactionManager.StartTransaction()
               Try
                   Dim prosta As Line = New Line(New
Point3d(rePoint.Value.X, rePoint.Value.Y, 0), New Point3d(rePoint.Value.X * 100,
rePoint.Value.Y, 0))
                   prosta.SetDatabaseDefaults()
                   Dim ra As Line = CType(trans.GetObject(prosta.Id,
OpenMode.ForWrite), Line)
                       Dim x As Double
                       Dim dl As Boolean = True
Point3dCollection()
ln.GetPlane(), tempptc, 0, 0)
                           If tempptc.Count > 0 And dl Then
                                   MsgBox("Second point" & x.ToString
& ":", MsgBoxStyle.Information)
                                   Dim prosta2 As Line = New Line(New
Point3d(rePoint.Value.X, rePoint.Value.Y, 0), New Point3d(x, rePoint.Value.Y,
0))
                                   btr.AppendEntity(prosta2)
                                   trans.AddNewlyCreatedDBObject(prosta2,
True)
                                   dl = False
                                   Exit For
                               Next
                           End If
                       Next
                   End If
                   ra.Erase(True)
                   trans.Commit()
                   lineCmd.WriteMessage("Error:" + ex.Message)
                   MsgBox(ex.Message)
               Finally
                   trans.Dispose()
               End Try
           End Using
       End If
   End Sub
End Class
Edited by vinayds
added code hashtag
