default templates
hi! im new here as well as revit mep. am using revit 2014 and i couldnt find the default templates.should anyone else help me? thank you
Did you download and install a trial? If so the content is downloaded through the install, which could have been opted out. You may need to run the install again and make sure Content is selected for download and install.
