HELP: Lisp to isolate a set of predefined layers base on their layer names.
I merged your two threads on this topic, you can ask for a LISP and/or a Macro in the same thread, no need for two threads on same question, it makes things confusing.
  vernonlee said:
I like to re-open this thread again as I frequently found out that instead of a fixed layer name, i have encounter layers that share the same name but with a slight difference.
So is it possible to incoporate a wildcard name eg. *rev*
Thanks
Yes, my posted code already allows you to do this.
Last night I realized that by adding * at the from & back of the text it works for the macro script.
Lee, this applies for your lisp as well? btw, can it isloate in paperspace now?
Thanks
try this, you can set upto x no. of layers.
;;predefine selection
(setq lay1 "?") ;;isolate layer 0 as (default)
;;define function
(defun c:test ()
;;turn on the echo command
(setvar "cmdecho" 1)
;;enter a layer name or press ENTER to skip
(setq clay1 (getstring (strcat "\nEnter layer name list <" lay1 ">: ")))
(if (= clay1 "")
    (setq clay1 lay1)
    (setq lay1 clay1)
;;Main
(command "-layer" "OFF" "*" "Y" "")
(command "-layer" "ON" lay1 "" "")
(command "zoom" "0.85x")
(defun c:ret () ;;define function
(command "-layer" "ON" "*" "") ;;turn on all layers
(command "zoom" "e")
(princ "\nEnter test to isolate & ret to return.")
(princ "\nttray33y @ CADTUTOR.")
i know someone here can write a shorter version for this, but anyway i am just sharing.
Edited by ttray33y
revised to add list of layers.
;;define function
(defun c:test ()
(if (= clay1 "")
    (setq clay1 lay1)
    (setq lay1 clay1)
;;Main
Thanks bro. I do need to have an option to have predefined layers within the lisp itself though.
Interesting lisp nevertheless
youre welcome bro.
