HELP: Lisp to isolate a set of predefined layers base on their layer names.
Can a kind soul come up with a macro script that can isolate a set of predefined layers base on their names.
Thanks
Edited by vernonlee
Any help on the above?
Thanks
  BIGAL said:
-la s 1stlayername off *
on layer2
on layer3
etc
Thanks. Tried it.
  Quote
^C^C-la s layer1 off*
I got this:
Command: -la -LAYER
Current layer: "layer1"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: s
Enter layer name to make current or
Also I have many layers. Is it possible to key only the layers that need to on without keying in the rest that needs to off?
Can someone come up with a lisp that can isolate a set of predefined layers base on their layer names (by adding it to the lisp).
Thanks
Off space * then ON do a layer list can be part* or part*,bolt*,nut* or part,nut,bolt or just repeat the ON bolt ON part on nut
Just watch the command line for the correct prompts.
You include my function _isolate into your lisp routine to isolate a list of layer names as shown below .
(defun _isolate (layers / l c n e)
 ;;    Tharwat 17.Nov.2014    ;;
 ;; Isolate a specifc list of     ;;
 ;; Layer names .        ;;
 (while (setq l (tblnext "LAYER" (not l)))
   (setq c (cdr (assoc 62
                       (setq e
                              (entget (tblobjname "LAYER" (setq n (cdr (assoc 2 l)))))
   (if (member n layers)
     (if (minusp c)
       (entmod (subst (cons 62 (abs c)) (assoc 62 e) e))
     (if (not (minusp c))
       (entmod (subst (cons 62 (- c)) (assoc 62 e) e))
Usage of the function :
(_isolate '("Layer1" "Layer2" "Layer3"))
Hi bro.
I did not get it at first but tried it & it worked.
It is a nice workaround, but it will only work if i can get back to the previous layering setting. Any idea on that?
Thanks
 ;; Layer names .        ;;
                       (setq e
     (if (minusp c)
Hi Tharwat.
I do not have a lisp routine to isolate. Can clarify?
Thanks
But you have mentioned in your first post that you want the codes to add them to a lisp ?
What clarification you are asking for ?
Edited by Tharwat
typo
If you are refering to the "........(by adding to the lisp)" in my 1st post, i was actually referring to looking for a standalone lisp, where i can key into that lisp; predefined layer names to isolate those layers when i run that lisp.
I hope that is clearer. :oops:
Have a look .
(defun c:Test ( / lays l c n e)
 ;; Layer names .                ;;
[color=red]  (setq lays '("Layer1" "Layer2" "Layer3")) ;; < Change this list of layer names to meet your needs .[/color]
                       (setq e
   (if (member n lays)
     (if (minusp c)
  Tharwat said:
Have a look .
 ;; Layer names .                ;;
                       (setq e
   (if (member n lays)
     (if (minusp c)
It worked. it did isolate the required layer. But the unisolate command would not get back the original layering setting before it "isolate"?
Can it be included into the lisp you have written?
Apologies for not being clearer.
Basically i needed to isolate a predefine layers, after i have amended the drawings, I would like for them to go back to what it was before the drawings was "isolated"
I did not mention eariler as i though the unisolate command will work.
Thanks
There is a command called LAYERP
It restores the previous layer settings.
I always return to all layers on, but if you have more complicated settings and want to return to some being on and some being off then try LAYERP.
Setting the variable "Expert" to 3 at start of your macro will prevent AutoCAD from asking you if you are sure you want to turn off current layer.
Thanks
You may look for something like this ?
NOTE: Don't forget to change the list of layer names as per yours .
(defun c:[color=red]Test-1[/color] (/ l n lst)
 (setq *Lays_Status1* nil
       *Lays_Status2* nil
       l              '([color=magenta]"Layer1" "Layer3" "Layer5"[/color])
 (vlax-for x (vla-get-layers
               (vla-get-activedocument (vlax-get-acad-object))
   (if (member (setq n (vla-get-name x)) l)
              (cons (list n (vla-get-layeron x))
                    *Lays_Status1*
       (vla-put-layeron x :vlax-true)
       (setq *Lays_Status2*
                    *Lays_Status2*
       (vla-put-layeron x :vlax-false)
(defun c:[color=blue]Test-2[/color] (/ l n as)
 (setq l '([color=magenta]"Layer1" "Layer3" "Layer5"[/color]))
 (if (and *Lays_Status1* *Lays_Status2*)
     (cond ((setq as (assoc (setq n (vla-get-name x)) *Lays_Status1*))
            (vla-put-layeron x (cadr as))
           ((setq as (assoc (setq n (vla-get-name x)) *Lays_Status2*))
       *Lays_Status2* nil
)(vl-load-com)
Cool. That more or less solve my issue. I will make another macro for the LAYERP & i should be good to go. Hurray!!
btw i check my expert setting , & it was 0. But it still off it without asking me.
Thanks bro. :)
Assuming you are using a version of AutoCAD in which the LAYISO command is available as standard, try the following:
(defun c:mylayiso ( / lay sel )
   (setq lay "layer1,layer2,layer3")
   (if (setq sel (ssget "_X" (list (cons 8 lay) (if (= 1 (getvar 'cvport)) (cons 410 (getvar 'ctab)) '(410 . "Model")))))
       (command "_.layiso" sel "")
You can then use the LAYUNISO command to unisolate the layers.
       *Lays_Status2* nil
                    *Lays_Status1*
                    *Lays_Status2*
       *Lays_Status2* nil
)(vl-load-com)
Thanks Tharwat. It worked. This is gonna be very useful. :D
Thanks Lee Mac. It works too.
I do like yours as well & if you can have it work in paperspace (layout tab) that would be even better. :sweat:
Good for you - you are welcome. :)
I like to re-open this thread again as I frequently found out that instead of a fixed layer name, i have encounter layers that share the same name but with a slight difference.
So is it possible to incoporate a wildcard name eg. *rev*
Thanks
