I have a drawing with lots of lines approx. 300mm long. Each of these lines is the centreline of a rectangle that is 20mm wide and the same length as the line.
So my CAD exercise is to offset the centreline 10mm in each direction and then connect the end points of these new lines to create a rectangle. And repeat several hundred times!
I know that a lisp routine should be able to do this for me and that it probably involves polar coordinates, but I am at a loss at how to do it.
Can anyone help?
Quickly done :)
(defun c:Test (/ ss i e 1p 2p a d p1 p2 p3 p4 _line)
 (defun _line (q p)
   (entmakex (list '(0 . "LINE") (cons 10 q) (cons 11 p)))
 (if (setq ss (ssget "_:L" '((0 . "LINE"))))
     (setq e  (entget (ssname ss (setq i (1- i))))
           1p (cdr (assoc 10 e))
           2p (cdr (assoc 11 e))
           a  (angle 1p 2p)
           d  (distance 1p 2p)
     (setq p1 (polar 1p (+ a (* pi 0.5)) 10.)
           p2 (polar p1 a d)
           p3 (polar 1p (+ a (* pi 1.5)) 10.)
           p4 (polar p3 a d)
     (mapcar '_line
             (list p1 p2 p4 p3)
             (list p2 p4 p3 p1)
That's brilliant Tharwat, exactly what I need, thank you.
Here's another way, using some trans trickery:
(defun c:l2r ( / i e l n p q s )
   (if (setq s (ssget '((0 . "LINE"))))
       (repeat (setq i (sslength s))
           (setq e (entget (ssname s (setq i (1- i))))
                 q (cdr (assoc 11 e))
                 n (mapcar '- p q)
                 l (mapcar
                      '(lambda ( x )
                           (mapcar '(lambda ( y ) (mapcar x (trans y 0 n) '(10 0 0)))
                               (list p q)
           (entmake
               (append
                  '(   (000 . "LWPOLYLINE")
                       (100 . "AcDbEntity")
                       (100 . "AcDbPolyline")
                       (090 . 4)
                       (070 . 1)
                   (mapcar '(lambda ( x ) (cons 10 (trans x n 0))) (append (car l) (reverse (cadr l))))
And another, using matrix math:
(defun c:l2r ( / a d e i p q s )
                 a (angle    p q)
                 d (distance p q)
           (entmake
               (append
                       (090 . 4)
                       (070 . 1)
                   (   (lambda ( m )
                           (mapcar '(lambda ( x ) (cons 10 (mapcar '+ p (mapcar '(lambda ( y ) (apply '+ (mapcar '* y x))) m))))
                                   (0.0 -0.5)
                                   (1.0 -0.5)
                                   (1.0  0.5)
                                   (0.0  0.5)
                       (list
                           (list (* (cos a) d) (* (sin a) -20.0))
                           (list (* (sin a) d) (* (cos a)  20.0))
You're welcome . :)
  • 7 years later...
Hi guys, what about drawing a polyline, open or closed, and by a simple click obtain (choosing a value 1, 2, 3....) an offset polyline, like i can do in 3D with polysolid  justify center.
Can you help me ?
