Family parameters export/import ?
Hi,
This is a shot in the dark but is it possible to export/import parameters (specifically shared parameters) from one family to another.
I have searched and it appears Autodesk supplied a plugin for subscription users to do this a while ago but it's not available now, unless I'm not looking in the correct place.
Any help will be appreciated
Many thanks Tannar,
I'll give them a go.
I'm fairly new to Revit and have a lot to learn....
Regards
Alex
Exciting times. Once you get a good grasp on Revit you'll never pick up AutoCAD ever again. :)
My problem is I'm using Revit LT at the moment and it does not allow external add-ins to be used.
All I want to do is import a family file shared parameters and it's values into a another family file, is this possible?
Shared Parameters are pulled from a single source *.txt file that is mapped from Manage Tab > Shared Parameters. Once this is mapped, you can use the Export option when you select a parameter and click Modify.
Ok thanks, I understand now.
Would be nice to be able to export a batch of them at once but I guess I would need to upgrade and use the available plugins.
