kizaerf Posted November 3, 2014 Posted November 3, 2014 Is there a quick shortcut for this, similar to Revit where you can hit Tab to click on objects that are under others? Thanks, Quote
nestly Posted November 3, 2014 Posted November 3, 2014 Selection Cycling (status bar toggle) is the newest and clearest method... although not necessarily the fastest. or Shift + Spacebar while in selection mode also How to cycle through overlapping objects for selection in AutoCAD Quote
Dana W Posted November 3, 2014 Posted November 3, 2014 Don't you get a pop-up selection list near the cursor, showing stacked or really really close objects when you click the select in? Quote
