Posting animated gif
This remains a problem, each time I try to post an animated gif it is changed to a .jpg file, the size is under 250kb (117kb) it doesn't matter if I try to use the add file or add image the result is the same. What am I missing
You need to re-record the video once again ( this is what I do when it took a place ).
The gifs are fine on my computer, put the forum software changes them to jpegs.
Agreed , it did happen with me a lot and I fixed that issue with another record of the same theme .
