Change Text divinding it by a number
Flip_73
Hello
I would like to have a simple lisp routine that divide all the numbers in a given layer by 20, can anybody help me?
Thx
Here is a quickly-written solution:
(defun c:divtxt ( / d e i n s )
   (initget 2)
   (if
       (and
           (setq d (getreal "\nSpecify divisor: "))
           (setq e (car (entsel "\nSelect object on layer to process: ")))
           (setq s
               (ssget "_X"
                   (append '((0 . "TEXT,MTEXT")) (kg:ssgetfilternum)
                       (list
                           (assoc 8 (entget e))
                           (if (= 1 (getvar 'cvport))
                               (cons 410 (getvar 'ctab))
                              '(410 . "Model")
       (repeat (setq i (sslength s))
           (if (setq e (entget (ssname s (setq i (1- i))))
                     n (distof (cdr (assoc 1 e)))
               (entmod (subst (cons 1 (LM:num->str (/ n d))) (assoc 1 e) e))
;; Number to String  -  Lee Mac
;; Converts a supplied numerical argument to a string
(defun LM:num->str ( x / dim rtn )
   (if (equal x (atof (rtos x 2 0)) 1e-
       (rtos x 2 0)
           (setq dim (getvar 'dimzin))
           (setvar 'dimzin
           (setq rtn (vl-catch-all-apply 'rtos (list x 2)))
           (setvar 'dimzin dim)
           (if (not (vl-catch-all-error-p rtn)) rtn)
(defun kg:ssgetfilternum ( ) ;; roy_043
       (1 . "~*[~-.0-9]*")
       (1 . "~*`.*`.*")
       (-4 . "<OR")
           (1 . "~*-*")
           (-4 . "<AND")
               (1 . "-*")
               (1 . "~*-*-*")
           (-4 . "AND>")
       (-4 . "OR>")
Thank you very much. It works perfectly.
  • 1 year later...
i want a lisp to divide many text values number by a perticular value????? please help
