lrm Posted January 21, 2015 Posted January 21, 2015 Try to make the aspect ratio of the viewport the same as the aspect ratio of the rendered images setting. For example, if you are rendering 680 x 480 or an aspect ratio of 4:3 try to manipulate the viewport shape to the same ratio. The easiest way to do that may be to drag the side of the AutoCAD window. Quote
zionshea Posted January 22, 2015 Author Posted January 22, 2015 Thanks a lot Irm - that, as usual, worked. Can you please take a look on another question I have in another post - http://www.cadtutor.net/forum/showthread.php?90458-Assigning-new-materials-to-walls Quote
