FIFTHTEXAS Posted October 31, 2014 Posted October 31, 2014 hi i am in process of trying to cut back a gable roof at an angle in a 3d view so i can view equipment, is there a way of doing this, i have been able to do it with whole model, i just need to cut back roof on one side. Quote
ReMark Posted October 31, 2014 Posted October 31, 2014 Just to confirm, you are doing this is Revit correct? Quote
FIFTHTEXAS Posted October 31, 2014 Author Posted October 31, 2014 hi yes i am doing this in revit 2015, i am applying some roof equipment and looking to put some cut-outs in the roof Quote
ReMark Posted October 31, 2014 Posted October 31, 2014 I think a similar question came up recently regarding slicing a roof in Revit. Did you happen to see it? Quote
FIFTHTEXAS Posted October 31, 2014 Author Posted October 31, 2014 no i have not seen it i will have a look through the forum, many thanks Quote
tzframpton Posted November 1, 2014 Posted November 1, 2014 I would use the Vertical Opening tool on the Architecture tab. Example below: http://screencast.com/t/ywujno2A90W Quote
