ReMark Posted November 4, 2014 Posted November 4, 2014 I can try to sabotage our copy of AutoCAD LT 2015 but I'll have to go over to the electrical department to do so. Everything I've tested so far has been in full AutoCAD. Maybe I am missing something. Is service pack 1 installed by the way? Quote
DonovanPorter Posted November 4, 2014 Author Posted November 4, 2014 yes all service packs are installed. Quote
nestly Posted November 4, 2014 Posted November 4, 2014 Does a new tab open if you type NEWTAB at the command line, or does it give a message about NEWTABMODE? Quote
DonovanPorter Posted November 4, 2014 Author Posted November 4, 2014 a new tab opens, but its blank (grey) same as the pic in my first post Quote
nestly Posted November 4, 2014 Posted November 4, 2014 Uncheck "Access online content when available" in the Options System tab and see if that makes a difference Quote
ReMark Posted November 4, 2014 Posted November 4, 2014 So far I've only come across one other person who has experienced the same problem. Unfortunately I could not duplicate the problem on our electrician's CAD system. At least he's happy. Quote
DonovanPorter Posted November 4, 2014 Author Posted November 4, 2014 i appreciate your efforts ReMark. Thank you, ill just use it the way its is, maybe one day when i have some time i will uninstall and reinstall from the disc. Quote
ReMark Posted November 4, 2014 Posted November 4, 2014 Should you do that then please visit the AutoDesk website and read up on the recommended procedure (clean install) otherwise you could be right back where you are now. Good luck. Quote
