hello
i have an existing dynamic block with several visibilities states.
i would like to add another one but when i did it, it changes one of the existing visibility state
my question is : how to add a visibility state to an existing block without changing existing states.
thanks
Phil
Attach a copy of the block (as a dwg file) to your next post along with an explanation of what exactly you want to add. Someone here will take a look at it.
hello
here the block that i'd like to modify
wwhen i create a new visibility state for the scale 1/40 it modifies the scale 1/1
if i modify the scale 1/1 modified it modifies my new scale 1/40
how create a new scale withou modifying the existing ones?
Phil
link : http://cjoint.com/?DJCmEaQkEOP
You need make a copy of the text items in the 1:40 visstate then make one set invisible (right click and choose hide in current state), then change the scale values for the remaining set in the new 1:40 visstate. At the moment it is the same items being used in both states.
greeeat!! :)
many thanks, it so easy you know this tip but when you don't...
Phil
  • 2 weeks later...
Or you can use the same text but add both annotative scales to the objects?
