Adding Xdata From Slected Mtext or Text
Hi,
I am creating lisp routine and the work is to selected Mtext or text and the corresponding content is to be added as Xdata to the selected entity.
(defun C:addxdata()
(setq a(entget(car(entsel"\nSelect Text: "))))
(setq Xdata1 (cdr (assoc 1 a)))
(princ Xdata1)
(setq b(entget(car(entsel"\nSelect Text: "))))
(setq Xdata2 (cdr (assoc 1 b)))
(princ Xdata2)
(regapp "Test_Xdata" )
(setq oldlist (entget (car (entsel))))
(setq thedata '((-3 ("Test_Xdata" (1000 . Xdata1) (1000 . Xdata2 )))))
Then I used list Xdata option available under Express tool Tab (Auto Cad 2014). I didn't find any Xdata Attached with it.
After Adding the Xdata, I wanna export to Excel.
For the Excel Conversion, Lisp is working good.
I guess the Problem is in the following line,
Eventhough the value stored in variable it is not working properly.
With Regards,
Karunakaran.
Thank you Lee I got it where I missed and the referred info are usefull.
