How to get the name of an object with autolisp
Mhmd
I'm trying to get the name of an object with auto lisp.
First a user will select an object and then I will get the name of that object for example: circle, rectangle, arc....
Here is what I have so far:
(setq ss (ssget (prompt ".....Select required object...")))
(ssname ss 0)
But this will give something like: "":(
I want to get something like: "circle", "line"...
Is this possible?
Is this possible?
hi, mhmd
welcome to forum.
(cdr(assoc 0 (entget (car (entsel)))))
try to look there are many examples codes in this forum.
You can do the same in VLISP its a vla-get-name
(setq objname (vla-get-objectname (vlax-ename->vla-object (car (entsel)))))
