how to rotate obj 90 degree in assemble world Inventor 2014
I tried to use the free rotate tool but i can't get to rotate 90 degree so that i perfectly set inside the frame structure. when i insert the tank Scrubber in the assembly how can rotate so Y coordinate go vertical?? any trick? or "free rotate" tool is the only option.
Thanks
never mind, i found it when i right click with 90 degree option
  • 1 month later...
LOL you found the answer in 5 mins, :) grip rotate or better still constraint it into position;)
grip rotate?? how to do?
