Hi
I have 96 different hatches.
I have a template block with only 2 lines of text: Area and Name.
I want this block to appear in the middle(ish) of a hatch when i click on it, with "Name" attribute beeing the layer the hatch is on, and the "Area" attribute of the block is the Area of the hatch, divided by 1000000 and m2 behind it.
Is this possible?
Yes it is using LISP or VBA. On which layer should the block be inserted? Does it have to be a block or would MText be acceptable?
I am running out of time on this project so I have to do it manually, cant afford to use time on automating it and maybe failing.
Thank you for your help!
