How to lighten or dim text ,lines & shapes in autocad
I am trying to do some modification in an already existing electrical lighting layout file. What I want to do is lighten the already made sketch and then draw new symbols over it. I have searched the internet but I could only find lightening raster but not whole diagrams. Can anybody guide how this is possible?
Is the lighting "layout" an actual Layout tab, or are you working on the drawing in the Modelspace tab?
If by lightening, you mean using it as a background for your new work and having it plot as such. You need a plot style that has shading or very thin lineweights set up or a combination of the two. Check out some tutorials on plotting.
If you mean on the monitor, I would set it up as an XREF and look into the XREF fade control variable. The layer lock fade control is another option.
I assume you are working on a new layer>
Set dimming on inactive layers.
(fading on locked layers)
laylockfadectl
range -90 to 90
0 locked layers not faded
90 locked layers faded by 90 percent
Tahir,
I believe what you are attempting to do is simply lighten the appearance of the line work in your 2D layout drawing, correct?
If that is the case then simply change the color of the existing line work to a gray color and use black for your new drawing color.
If you want to plot the same results then after making the modifications then adjust your color settings under the plot dialog.
  • 2 weeks later...
Thanks Patrick. Did just that and achieved what i wanted
