Pelle Posted October 9, 2014 Posted October 9, 2014 Hi All Im sitting with at little quistion, because I have alot of dwg's with different blocks in them. I now need to change one specific block with another block. Since I have around 100 drawings where I have to change the block then I was hoping that there would be an easy way so I don't have to go in manually in each dwg. Can you help me or give me some hints on how to do this? FYI: I can not change the old block in block editor because I still need it. Quote
BIGAL Posted October 10, 2014 Posted October 10, 2014 Using VL lisp you can PUT a new block name against an existing block you would read stuff like scale rotation etc as well. Then you could script the 100 dwgs and just churn through very quickly. script open dwg1 (load "blkchange") close Y open dwg2 etc ; this is just to show how it could be done (setq blkobj (vlax-ename->vla-object(car (entsel "\nPick block")))) ; (setq blkoldname (vla-get-name blkobj)) ; just here to show GET method for block name for ssget (setq newblk (getstring "\Enter name of new block")) ; note is case sensitive ; need ssget here all blocks ; need vlax-for here to go through all blocks (vla-put-name blkobj newblk) ; updates block Quote
BIGAL Posted October 10, 2014 Posted October 10, 2014 Version 2 like Dadgad just script it open dwg1 -blockreplace oldblockname newblockname N close Y open dwg2 -blockreplace oldblockname newblockname N close Y open dwg3 -blockreplace oldblockname newblockname N close Y Quote
N3cr0Rav3 Posted January 29, 2018 Posted January 29, 2018 Hi, could someone help me with that lisp or send to me something other, i use a changeblock.lisp, program works excellent, but i need to change block with their base point, that can be possible? (defun c:CHANGEBLOCK(/ ACTDOC COPOBJ ERRCOUNT EXTLST EXTSET FROMCEN LAYCOL MAXPT CURLAY MINPT OBJLAY OKCOUNT OLAYST SCLAY TOCEN TOOBJ VLAOBJ *ERROR*) (vl-load-com) (defun *ERROR*(msg) (if olaySt (vla-put-Lock objLay olaySt) ); end if (vla-EndUndoMark actDoc) (princ) ); end of *ERROR* (defun GetBoundingCenter(vlaObj / blPt trPt cnPt) (vla-GetBoundingBox vlaObj 'minPt 'maxPt) (setq blPt(vlax-safearray->list minPt) trPt(vlax-safearray->list maxPt) cnPt(vlax-3D-point (list (+(car blPt)(/(-(car trPt)(car blPt))2)) (+(cadr blPt)(/(-(cadr trPt)(cadr blPt))2)) 0.0 ); end list ); end vlax-3D-point ); end setq ); end of GetBoundingCenter (if(not(setq extSet(ssget "_I"))) (progn (princ "\nSelect objects, need to replace ") (setq extSet(ssget)) ); end progn ); end if (if(not extSet) (princ "\nDistination objects isn't selected!") ); end if (if (and extSet (setq toObj(entsel "\nSelect original object ")) ); and and (progn (setq actDoc (vla-get-ActiveDocument (vlax-get-Acad-object)) layCol (vla-get-Layers actDoc) extLst (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr(ssnamex extSet)))) vlaObj(vlax-ename->vla-object(car toObj)) objLay(vla-Item layCol (vla-get-Layer vlaObj)) olaySt(vla-get-Lock objLay) fromCen(GetBoundingCenter vlaObj) errCount 0 okCount 0 ); end setq (vla-StartUndoMark actDoc) (foreach obj extLst (setq toCen(GetBoundingCenter obj) scLay(vla-Item layCol (vla-get-Layer obj)) );end setq (if(/= :vlax-true(vla-get-Lock scLay)) (progn (setq curLay(vla-get-Layer obj)) (vla-put-Lock objLay :vlax-false) (setq copObj(vla-copy vlaObj)) (vla-Move copObj fromCen toCen) (vla-put-Layer copObj curLay) (vla-put-Lock objLay olaySt) (vla-Delete obj) (setq okCount(1+ okCount)) ); end progn (setq errCount(1+ errCount)) ); end if ); end foreach (princ (strcat "\n" (itoa okCount) " were changed. " (if(/= 0 errCount) (strcat (itoa errCount) " were on locked layer! ") "" ); end if ); end strcat ); end princ (vla-EndUndoMark actDoc) ); end progn (princ "\nSource object isn't selected! ") ); end if (princ) ); end of c:CHANGEBLOCK Quote
