Damon :) Posted October 2, 2014 Posted October 2, 2014 How do you use grips to modify an entity? Quote
ReMark Posted October 2, 2014 Posted October 2, 2014 This simple tutorial about using Grips in AutoCAD should get you started. For further information consult your AutoCAD Help file. Do you know how to do that? https://www.andrew.cmu.edu/course/48-568/PDFs/AutoCAD2D/Chapter22.pdf You might also benefit from the purchase of a good after-market AutoCAD book. Many such books can be found via Amazon. I'd recommend the series by George Omura published by Sybex. Quote
rkmcswain Posted October 2, 2014 Posted October 2, 2014 First, understand that is like asking "how do I drive a car?" It is not easily put into a couple of paragraphs. If you can take 12-1/2 minutes, this tutorial should help you a lot: Quote
