Euga Posted September 30, 2014 Share Posted September 30, 2014 Hello Can someone explain me the difference between two AutoCAD commands: purge and -purge, all, *,n. Thanks Quote Link to comment Share on other sites More sharing options...
rkent Posted September 30, 2014 Share Posted September 30, 2014 purge will give you the dialog box, -purge will show at the command line. -purge will show you extra things that can be purged but they are not included in the 'all' option. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted September 30, 2014 Share Posted September 30, 2014 Don't forget to purge those registry applications (regapps). Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 30, 2014 Share Posted September 30, 2014 One of the recommended procedures I've seen to clean out a drawing files goes like this. Run Overkill to remove overlapping and duplicate lines. Run -Purge...purging Regapps first. Repeat -Purge but this time do a purge > All. Run the Audit command. Say "yes" to fixing errors. Zoom extents. Save. Repeat the entire procedure. Done. Quote Link to comment Share on other sites More sharing options...
Euga Posted October 1, 2014 Author Share Posted October 1, 2014 So I can use either purge either -purge,all,*,n. There are no point to make both commands? Thank you all for advices and explanations. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted October 1, 2014 Share Posted October 1, 2014 So I can use either purge either -purge,all,*,n. There are no point to make both commands? Psst, I thnk you missed something... -purge will show you extra things that can be purged but they are not included in the 'all' option. Quote Link to comment Share on other sites More sharing options...
