Faouweb Posted September 29, 2014 Posted September 29, 2014 Hi, I have a 3d structure, and I want to know if there is a way to know the mass? What I do at the moment is, I find the Volume 'OBJECT' divide it by 10^9 and in the end times the density of the material. If its possible I want to learn how to do it with FORMULA in a TEXT FIELD. Thank you Quote
Faouweb Posted September 30, 2014 Author Posted September 30, 2014 Thank you BIGAL, Where can I put the Density of the material? in my case steel 7840 kg/m3. Quote
Faouweb Posted October 1, 2014 Author Posted October 1, 2014 Is it possible to add a new Variables in Calculator, as shown in the screen shot? Thank you. Quote
SLW210 Posted October 1, 2014 Posted October 1, 2014 Yes, you can add new Variables to Calculator. http://www.ellenfinkelstein.com/acadblog/create-a-custom-function-in-autocads-calculator/ Also for a LISP solution http://cadtips.cadalyst.com/mass-properties/tip-2258-calculate-weight or http://cadtips.cadalyst.com/mass-properties/determine-weights-3d-objects Quote
