kenth Posted September 26, 2014 Share Posted September 26, 2014 Hello, how do I reduce the spacings shown as red lines in the pic? Quote Link to comment Share on other sites More sharing options...
BlackBox Posted September 26, 2014 Share Posted September 26, 2014 Hello, how do I reduce the spacings shown as red lines in the pic? In Toolspace, Settings tab, expand Section View node, expand Commands node, right click on CreateMultipleSectionView Command, and select Edit Command Settings... menu item. In the Edit Command Settings dialog, expand Table Creation node, and if memory severs you modify Table Spacing value. Cheers Quote Link to comment Share on other sites More sharing options...
kenth Posted September 29, 2014 Author Share Posted September 29, 2014 Thanks BlackBox, that did have some effect in reducing the spacing. Quote Link to comment Share on other sites More sharing options...
Luthuli S Posted November 11, 2021 Share Posted November 11, 2021 Good afternoon I am a novice in design using civil 3d. can you please tell me which design template do you use because at work i found out they are using Devotec. I would be glad if i was just designing without a template because this is limiting me. When i am doing cross section they come out small while i used 1:250 can you also assist in that regard. Quote Link to comment Share on other sites More sharing options...
